h = flight maximum elevation (m, ft)
The horizontal distance of the flight can be expressed as
s = v i 2 sin(2 Θ ) / a g (4)
s = flight distance (m, ft)
A ball is thrown with initial velocity 25 m/s in angle 30 degrees to the horizontal plane. The time for the ball to reach maximum level is
t h = ( 25 m/s ) sin(30 degrees) / ( 9.81 m/s 2 )
= 1.27 s
The maximum elevation of the ball can be calculated as
h = 1/2 ( 9.81 m/s 2 ) ( 1.27 s < ) 2
= 7.91 m
The horizontal distance traveled by the ball can be calculated as
s = ( 25 m/s ) 2 sin(2 30 degrees ) / ( 9.81 m/s 2 )
= 55.2 m
The calculator below can be used to estimate the time of flight, time to reach maximum elevation, maximum elevation and flight distance for a projectile like a bullet or a ball or something similar.
Note that friction force due to air resistance is neglected.
Note that friction force due to air resistance is neglected in the charts above. For higher velocities range and maximum height will be dramatically reduced.
Motion - velocity and acceleration, forces and torque.
Acceleration of gravity and Newton's Second Law - SI and Imperial units.
Angular velocity and acceleration vs. power and torque.
Forces due to circular motion and centripetal / centrifugal acceleration.
The momentum of a body is the product of its mass and velocity - recoil calculator.
Velocity plotted in time used diagram.
Forces acting a very short time are called impulse forces.
Energy possessed by an object's motion is kinetic energy.
Orbital and escape velocity for geostationary satellites.
