Disk Brakes - Torque and Force
The torque capacity of a disk brake with two pads can be expressed as
T = 2 μ F r (1)
T = braking torque (Nm)
F = force on each pad (N)
r = mean radius (from center wheel to center pad) (m)
Required pad pressure can be expressed as
p = F / A (2)
p = pressure (Pa)
A = pad area (m2)
• Mechanics
Acceleration
Change in velocity vs. time used.
Acceleration Units Converter
Converting between units of acceleration.
Car Acceleration
Car acceleration calculator.
Force
Friction - Coefficients for Common Materials and Surfaces
Find friction coefficients for various material combinations, including static and kinetic friction values. Useful for engineering, physics, and mechanical design applications.
Improvised Torque Wrench
Piston Engines - Displacement
Calculate piston engine displacement.
Rolling Resistance
Rolling friction and rolling resistance.
