Improvised Torque Wrench
If you don't have a torque wrench available - or if you want to check the readings of the one you have - it is easy to improvise by using a standard wrench and a scale as indicated in the figure above.
The moment - or torque - can be calculated
T = F a                                       (1)
T = moment or torque (Nm, lbf ft)
F = applied force (N, lbf)
a = length of the wrench (m, ft)
Note! - Most scales in the SI unit system measures weight - force due to the acceleration of gravity - in kg .
The reading from the scale can be converted to N by using
F = m g
m = reading of the scale (kg, lbf)
g = acceleration of gravity (9.81 m/s2, 32.17 ft/s2)
Example - Measuring Torque with a standard Wrench and a Luggage Scale - readings in kg
The reading of the scale at the end of the wrench is 10 kg . The length of the wrench is 0.3 m . The moment exerted can be calculated
T = (10 kg) (9.81 m/s2) (0.3 m)
= 29.4 Nm
Example - Measuring Torque with a standard Wrench and a Luggage Scale - readings in lbf
The reading of the scale at the end of the wrench is 20 lbf . The length of the wrench is 6 in . The moment exerted can be calculated
T = (20 lbf) (6 in)
= 120 in lbf
= 10 lbf ft
" Luggage Weight - Wrench " Online Torque Calculator
Scale Wrench Torque Diagram - SI units
Download and print Scale Wrench Torque Diagram
Example - Torque Settings for a Cylinder Head
The torque settings for a cylinder head in a car engine are specified to 30 Nm.
According to the diagram above with a wrench with length 0.2 m - the scale readings should be approximately
14 kg
Scale Wrench Torque Diagram - Imperial units
Fasteners
Mechanics
Angular Motion - Power and Torque
Angular velocity and acceleration vs. power and torque.
Bolt Torque Calculator: Loads & Preloads Data and Calculator
Calculate required bolt torque.
Car - Required Power and Torque
Power, torque, efficiency and wheel force acting on a car.
Disk Brakes - Torque and Force
Forces and torque activated with disk brakes.
Electric Motors - IEC and NEMA Standard Torques
IEC and NEMA torque classifications of electrical motors.
Forces Acting on a Wedge
Large forces can be introduced with the aid of wedges.
Gear Reducing Formulas
Output torque, speed and horsepower with gears.
Levers
Use levers to magnify forces.
Lifting Wheels
Loads and effort force with lifting wheels.
Piston Engines - Displacement
Calculate piston engine displacement.
Screw Jack - Effort Force vs. Load
Screw jacks and effort forces.
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area.
Torque - Work done and Power Transmitted
The work done and power transmitted by a constant torque.
Torque Specifications for Metric Bolts: Maximum Values & Tables
U.S. Bolts - Tightening Torques
Recommended bolt torques.
Whitworth Bolt Torques
Torque specifications Whitworth bolts.
