Torque Specifications for Metric Bolts: Maximum Values & Tables
Maximum recommended tightening torque for coarse threaded metric steel bolts:
Metric Bolts - Typical Tightening Torques
Size
(mm)
Max. Tightening Torque (Nm)
Property Class
Grade 8.8Grade 9.8Grade 10.9Grade 12.9
M5 7.0 7.8 10.0 11.7
M6 11.8 13.3 17.0 19.9
M8 28.8 32.3 41.3 48.3
M10 57.3 64.1 81.8 95.7
M12 99.8 112 143 167
M16 248 277 354 413
M20 500 690 809
M24 865 1195 1395
M30 1719 2377 2774
Fasteners
Bolt Torque Calculator: Loads & Preloads Data and Calculator
Calculate required bolt torque.
Improvised Torque Wrench
ISO 724 - Metric Threads
Metric Bolt Heads and Wrench Sizes
ANSI/SO, DIN and JIS bolts.
Metric Nuts - Proof Loads
Proof loads of metric nuts - coarse and fine threads.
Threaded Bolts - Stress Area
Threaded bolts tensile stress area.
Threaded Rods - Loads in Imperial Units
Weight rating of threaded hanger rods.
U.S. Bolts - Tightening Torques
Recommended bolt torques.
Whitworth Bolt Torques
Torque specifications Whitworth bolts.
