Threaded Bolts - Stress Area
The weakest points in a bolt is the stressed area in the thread root. The stressed area depends on the type of threads - coarse threads reduces the stressed area compared to fine threads.
UN and UNR Bolts Tensile Stress Area
The stressed area in a bolt can be calculated as
A = (π / 4)  (dn - 0.9743/ n)2                                      (1)
A = stressed area (in2)
dn = nominal bolt diameter (in)
n = 1 / p = number of threads per inch
p = pitch, length per thread (in)
Despite that a reduced area will reduce the breaking load of a bolt - coarse threads are used for clamping. Fine threads bolts are weaker due to the reduced thread height.
ISO 898 Bolts Tensile Stress Area
Tensile stress area in bolts according ISO 898-1 Mechanical properties of fasteners made of carbon steel and alloy steel:
As,nom = (π / 4) ((d2 + d3)/ 2)2                        (2)
As,nom = nominal stress area (m, mm2)
d2 = the basic pitch diameter of the external thread according ISO 724 ISO general-purpose metric screw threads -- Basic dimensions (m, mm)
d3 = d1 - H / 6 = the minor diameter of external tread (m, mm)
d1 = the basic minor diameter of external thread according ISO 724
H = the height of the fundamental triangle of the thread according ISO 68-1 ISO general purpose screw threads (m, mm)
Fasteners
Miscellaneous
Bolt Torque Calculator
Calculate required bolt torque.
ISO 724 - Metric Threads
Metric Bolt Heads and Wrench Sizes
ANSI/SO, DIN and JIS bolts.
Metric Bolts - Minimum Ultimate Tensile and Proof Loads
Metric Bolts - Tightening Torques
Reduced Torque with Lubricated Bolts
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
Stress
UNC and UNF - Unified Inch Screw Threads
US Bolts - Tensile Strength and Proof Loads
Wrench Spanners - Inches vs. mm
Convert between US Inches and metric mm wrench and spanner sizes.
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
