Steel Bolts - SAE Grades
SAE GradeHead MarkingSize Range
(in)
Minimum Proof Strength
(103 psi)
Minimum Tensile Strength
(103 psi)
Material
1 1/4 - 1 1/2     Low - medium carbon steel
2 1/4 - 3/4
7/8 - 1 1/2
55
33
74
60
5 1/4 - 1
1 1/8 - 1 1/2
85
74
120
105
Medium carbon steel, Q & T
5.2 1/4 - 1 85 120 Low carbon martensite steel, Q & T
7 1/4 - 1 1/2 105 133 Medium carbon alloy steel, Q & T
8 1/4 - 1 1/2 120 150 Medium carbon alloy steel, Q & T
8.2 1/4 - 1 120 150 Low carbon martensite steel, Q & T
  • 1 psi (lb/in2) = 6,894.8 Pa (N/m2)
Fasteners
Mechanics
Cast Iron Flanges - ASME/ANSI Class 125
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 125 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Flanges - API vs. ASME/ANSI
API and ASME/ANSI flanges - comparing dimensions and pressure ratings.
Flanges - ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 150 to 2500
Diameters and bolt circles for standard ASME B16.5 flanges - 1/4 to 24 inches - Class 150 to 2500.
Forged Steel Flanges - Stud Charts
Number of studs, diameter and length for ANSI forged steel flanges ranging class 150 to 1500.
Hardwood and Softwoods - Recommended Drill Bit Speeds
Hardwood and softwood drill speed chart.
ISO 724 - Metric Threads
Japanese industrial flanges, bolts, nuts, and gaskets standards and specifications from JAS - the Japanese Standards Association.
Metric Bolt Heads and Wrench Sizes
ANSI/SO, DIN and JIS bolts.
Reduced Torque with Lubricated Bolts
Steel Bolts - ASTM Grades
Steel Pipe Flanges for Waterworks Services
Threaded Bolts - Stress Area
Threaded bolts tensile stress area.
UNC and UNF - Unified Inch Screw Threads
US Bolts - Head and Wrench Sizes
Hex Bolt, Lag Bolt, Square Bolt and Heavy Hex Bolt.
US Bolts - Tensile Strength and Proof Loads
US Bolts - Tightening Torques
Recommended bolt torques.
US Hex Bolts - Inches
ANSI/ASME B18.2.1 Dimensions of Hex Bolts - Imperial units.
US Hex Bolts - Metric
Whitworth Bolt Torques
Torque specifications Whitworth bolts.
