NPS (in) | No. of Studs | Diameter of Stud (in) | Length of Stud (in) |
1/2 | 4 | 1/2 | 2-3/4 |
3/4 | 4 | 5/8 | 3-1/4 |
1 | 4 | 5/8 | 3-1/4 |
1-1/4 | 4 | 5/8 | 3-1/2 |
1-1/2 | 4 | 3/4 | 3-3/4 |
2 | 8 | 5/8 | 3-3/4 |
2-1/2 | 8 | 3/4 | 4-1/4 |
3 | 8 | 3/4 | 4-1/2 |
3-1/2 | 8 | 3/4 | 4-1/2 |
4 | 8 | 3/4 | 4-3/4 |
5 | 8 | 3/4 | 5 |
6 | 12 | 3/4 | 5 |
8 | 12 | 7/8 | 5-3/4 |
10 | 16 | 1 | 6-1/2 |
12 | 16 | 1-1/8 | 7 |
14 | 20 | 1-1/8 | 7-1/4 |
16 | 20 | 1-1/4 | 7-3/4 |
18 | 24 | 1-1/4 | 8 |
20 | 24 | 1-1/4 | 8-1/4 |
24 | 24 | 1-1/2 | 9-1/4 |
1/2 | 4 | 1/2 | 3-1/4 |
3/4 | 4 | 5/8 | 3-3/4 |
1 | 4 | 5/8 | 3-3/4 |
1-1/4 | 4 | 5/8 | 4 |
1-1/2 | 4 | 3/4 | 4-1/2 |
2 | 8 | 5/8 | 4-1/2 |
2-1/2 | 8 | 3/4 | 5 |
3 | 8 | 3/4 | 5-1/4 |
3-1/2 | 8 | 7/8 | 5-3/4 |
4 | 8 | 7/8 | 5-3/4 |
5 | 8 | 7/8 | 6 |
6 | 12 | 7/8 | 6-1/4 |
8 | 12 | 1 | 7 |
10 | 16 | 1-1/8 | 7-3/4 |
12 | 16 | 1-1/4 | 8-1/4 |
14 | 20 | 1-1/4 | 8-1/2 |
16 | 20 | 1-3/8 | 9 |
18 | 24 | 1-3/8 | 9-1/4 |
20 | 24 | 1-1/2 | 9-3/4 |
24 | 24 | 1-3/4 | 10-3/4 |
4 | 8 | 7/8 | 6 |
5 | 8 | 1 | 6-3/4 |
6 | 12 | 1 | 7 |
8 | 12 | 1-1/8 | 7-3/4 |
10 | 16 | 1-1/4 | 8-3/4 |
12 | 20 | 1-1/4 | 9 |
14 | 20 | 1-3/8 | 9-1/2 |
16 | 20 | 1-1/2 | 10-1/4 |
18 | 20 | 1-5/8 | 11 |
20 | 24 | 1-5/8 | 11-1/2 |
24 | 24 | 1-7/8 | 13 |
3/4 | 4 | 3/4 | 4-3/4 |
1 | 4 | 7/8 | 5-1/4 |
1-1/4 | 4 | 7/8 | 5-1/4 |
1-1/2 | 4 | 1 | 5-3/4 |
2 | 8 | 7/8 | 6 |
2-1/2 | 8 | 1 | 6-1/2 |
3 | 8 | 7/8 | 6 |
4 | 8 | 1-1/8 | 7 |
5 | 8 | 1-1/4 | 7-3/4 |
6 | 12 | 1-1/8 | 7-3/4 |
8 | 12 | 1-3/8 | 9 |
10 | 16 | 1-3/8 | 9-1/2 |
12 | 20 | 1-3/8 | 10-1/4 |
14 | 20 | 1-1/2 | 11 |
16 | 20 | 1-5/8 | 11-1/2 |
18 | 20 | 1-7/8 | 13 |
20 | 20 | 2 | 14 |
24 | 20 | 2-1/2 | 17-1/2 |
2 | 8 | 7/8 | 6 |
3 | 8 | 1-1/8 | 7-1/4 |
4 | 8 | 1-1/4 | 8 |
5 | 8 | 1-1/2 | 10 |
6 | 12 | 1-3/8 | 10-1/2 |
8 | 12 | 1-5/8 | 11-3/4 |
10 | 12 | 1-7/8 | 13-1/2 |
12 | 16 | 2 | 15 |
14 | 16 | 2-1/4 | 16-1/2 |
16 | 16 | 2-1/2 | 18 |
18 | 16 | 2-3/4 | 19-1/2 |
20 | 16 | 3 | 21-1/2 |
24 | 16 | 3-1/2 | 24-1/2 |
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 300 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
The number, diameter and length of studs for cast iron flanges class 125 and 250.
