PN Pressure Ratings for Flanges: Specifications & Standards
Piping Class Ratings based on the ASME B16.5 - Pipe Flanges and Flanged Fittings: NPS 1/2 through NPS 24 Metric/Inch Standard - class and the corresponding ISO 7005 PN (Pression Nominal*) ratings:
Flange Class | 150 | 300 | 400 | 600 | 900 | 1500 | 2500 |
Flange Pressure Nominal (PN) | 20 | 50 | 68 | 110 | 150 | 260 | 420 |
* "Pression Nominal" is the French equivalent of Pressure Nominal
"Pression Nominal" is the rating designator followed by a designation number indicating the approximate pressure rating in bars.
- 1 bar = 1×105 Pa (N/m2) = 0.1 N/mm2 = 10,197 kp/m2 = 10.20 m H2O = 0.98692 atm = 14.5038 psi (lbf/in2)
PN ratings do not provide a proportional relationship between different PN numbers, whereas class numbers do. Class numbers are therefore recommended before PN ratings.
Note! The piping rating must follow the pressure-temperature rating of the weakest pressure containing item in the system.
• Piping Codes and Standards
• Pressure Ratings of Pipes and Fittings
Aluminum Tubing - Allowable Pressures
Allowable pressure for aluminum tubes.
ASME - American Society of Mechanical Engineers
ASME is one of the leading organizations in the world developing codes and standards.
ASTM Flanges - Hydrostatic Test Pressures
Flanged fittings and required hydrostatic test pressure.
Bronze Flanges - ASME/ANSI 150 lb
Flange diameters, thickness, bolt circles, numbers and diameters of bolts for ASME/ANSI B16.15 - Cast Bronze Threaded Fittings - 150 lb Bronze flanges with plain faces.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 900
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 900 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon Steel Flanges - Pressure and Temperature Ratings
Maximum ratings for flanges conforming to ISO Standard 2229 dimensions and material specification AST-A-105.
Carbon Steel Pipes - Pressure and Temperature Ratings, Imperial Units
Pressure (psig) and temperature (deg F) ratings for A-53 B and A-106 B, A333, A334 and API 5L carbon steel pipes - temperatures ranging 100 degF - 700 degF.
Carbon Steel Pipes - Pressure and Temperature Ratings, Metric Units
Pressure (kPa)> and temperature (degC) ratings of ASTM A-106, API 5L and ASTM A-53 Seamless Carbon Steel Pipes - temperatures ranging -29 degC - 450 degC.
Cast Iron Threaded Pipe Fittings - Working Pressures vs. Temperature
Maximum working pressures for cast iron threaded pipe fittings according ANSI B16.4.
Forged Steel Flanges - Stud Charts
Number of studs, diameter and length for ANSI forged steel flanges ranging class 150 to 1500.
Malleable Iron Threaded Fittings - Pressure vs. Temperature Rating
ASME/ANSI B16.3 Malleable Iron Threaded Fittings - Pressure and Temperature Ratings.
NPS (Nominal Pipe Size) Guide: Dimensions, Charts & Specifications
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
Pipe Flanges and Gaskets - Dimensions
Gasket dimensions according ASME B16.5 Pipe Flanges and Flange Fittings.
Schedule - Terminology
Introduction to the schedule terminology of pipes.
