ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 150 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts for Weld neck, Threaded, Slip-on, Lap joint, Socket weld and Blind flanges.
Carbon and stainless steel qualities according ASME B16.5 Table 1A.
Pipe Size (inches) | Flange Outside Diameter (inches) | Pipe Outside Diameter (inches) | Number of Bolt Holes | Bolt Hole Diameter (inches) 1) | Bolt Circle (inches) |
1/2 | 3-1/2 | 0.84 | 4 | 5/8 | 2-3/8 |
3/4 | 3-7/8 | 1.05 | 4 | 5/8 | 2-3/4 |
1 | 4-1/4 | 1.32 | 4 | 5/8 | 3-1/8 |
1-1/4 | 4-5/8 | 1.66 | 4 | 5/8 | 3-1/2 |
1-1/2 | 5 | 1.90 | 4 | 5/8 | 3-7/8 |
2 | 6 | 2.38 | 4 | 3/4 | 4-3/4 |
2-1/2 | 7 | 2.88 | 4 | 3/4 | 5-1/2 |
3 | 7-1/2 | 3.50 | 4 | 3/4 | 6 |
3-1/2 | 8-1/2 | 4.00 | 8 | 3/4 | 7 |
4 | 9 | 4.50 | 8 | 3/4 | 7-1/2 |
5 | 10 | 5.56 | 8 | 7/8 | 8-1/2 |
6 | 11 | 6.63 | 8 | 7/8 | 9-1/2 |
8 | 13-1/2 | 8.63 | 8 | 7/8 | 11-3/4 |
10 | 16 | 10.75 | 12 | 1 | 14-1/4 |
12 | 19 | 12.75 | 12 | 1 | 17 |
14 | 21 | 14.00 | 12 | 1-1/8 | 18-3/4 |
16 | 23-1/2 | 16.00 | 16 | 1-1/8 | 21-1/4 |
18 | 25 | 18.00 | 16 | 1-1/4 | 22-3/4 |
20 | 27-1/2 | 20.00 | 20 | 1-1/4 | 25 |
24 | 32 | 24.00 | 20 | 1-3/8 | 29-1/2 |
1) Recommended bolts are 1/8 smaller than the nominal bolt hole diameters shown.
- 1 inch = 25.4 mm
- make 3D models with the Engineering ToolBox Sketchup Extension - Insert Flanges
• Piping Systems
ASME - American Society of Mechanical Engineers
ASME is one of the leading organizations in the world developing codes and standards.
Bronze Flanges - ASME/ANSI 150 lb
Flange diameters, thickness, bolt circles, numbers and diameters of bolts for ASME/ANSI B16.15 - Cast Bronze Threaded Fittings - 150 lb Bronze flanges with plain faces.
Butt-Welding Fittings - Dimensions
Butt-Welding Fittings - B16.9 - dimensions.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 1500
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 1500 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 2500
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 2500 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 300
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 300 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 400
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 400 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 600
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 600 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 900
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 900 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Welding Neck Flange Bores
Flange bores of welding neck flanges according ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings.
Carbon Steel Flanges - Group 1.1 Pressure and Temperature Ratings
Maximum temperature and pressure ratings of flanges conforming dimensions ASME B16.5 and materials specification ASTM A-105.
Carbon Steel Flanges - Pressure and Temperature Ratings
Maximum ratings for flanges conforming to ISO Standard 2229 dimensions and material specification AST-A-105.
Forged Steel Flanges - Stud Charts
Number of studs, diameter and length for ANSI forged steel flanges ranging class 150 to 1500.
PN Pressure Ratings for Flanges: Specifications & Standards
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Stainless Steel Weld Fittings - ANSI/ASME B36.19
Dimensions of stainless steel weld fittings according ANSI/ASME B36.19.
Stainless Steels - Identification Tests
Magnetic, spark, hardness and acid identification tests for austenitic, martensitic and ferritic stainless steels.
Steel Pipes - De-Rating vs. Temperature
Temperature derating factor for steel pipes.
