Carbon and Stainless Steel Flanges - ASME/ANSI Class 400
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 400 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts for Weld neck, Threaded, Slip-on, Lap joint, Socket weld and Blind flanges.
Carbon and stainless steel qualities according ASME B16.5 Table 1A.
Pipe Size
(inches)
Flange Outside Diameter
(inches)
Pipe Outside Diameter
(inches)
Number of Bolt HolesBolt Hole Diameter
(inches) 1)
Bolt Circle
(inches)
1/2 3-3/4 0.84 4 5/8 2-5/8
3/4 4-5/8 1.05 4 3/4 3-1/4
1 4-7/8 1.32 4 3/4 3-1/2
1-1/4 5-1/4 1.66 4 3/4 3-7/8
1-1/2 6-1/8 1.90 4 7/8 4-1/2
2 6-1/2 2.38 8 3/4 5
2-1/2 7-1/2 2.88 8 7/8 5-7/8
3 8-1/4 3.50 8 7/8 6-5/8
3-1/2 9 4.00 8 1 7-1/4
4 10 4.50 8 1 8-7/8
5 11 5.56 8 1 9-1/4
6 12-1/2 6.63 12 1 10-5/8
8 15 8.63 12 1-1/8 13
10 17-1/2 10.75 16 1-1/4 15-1/4
12 20-1/2 12.75 16 1-3/8 17-3/4
14 23 14.00 20 1-3/8 20-1/4
16 25-1/2 16.00 20 1-1/2 22-1/2
18 28 18.00 24 1-1/2 24-3/4
20 30-1/2 20.00 24 1-5/8 27
24 36 24.00 24 1-7/8 32
1) Recommended bolts are 1/8 smaller than the nominal bolt hole diameters shown.
  • 1 inch = 25.4 mm
Piping Systems
Carbon and Stainless Steel Flanges - ASME/ANSI Class 1500
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 1500 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 2500
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 2500 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 300
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 300 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 900
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 900 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Welding Neck Flange Bores
Flange bores of welding neck flanges according ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings.
Gasket Characteristics
Gaskets are used to make a fluid or gas resistant seal between two surfaces.
Steel Pipe Flanges for Waterworks Services
