ASME/ANSI B16.15 - Cast Bronze Threaded Fittings - 300 lb bronze flanges have plain faces with two concentric gasket retaining grooves between the port and the holes.
For full table with larger sizes - rotate the screen!
ANSI 300 lb Bronze Flanges
Pipe Size (inches)1/23/411 1/41 1/222 1/233 1/24568
Diameter of Flange
(inches)
3 3/4 4 5/8 4 7/8 5 1/4 6 1/8 6 1/2 7 1/2 8 1/4 9 10 11 12 1/2 15
Thickness of Flange
(inches)
1/2 17/32 19/32 5/8 11/16 3/4 13/16 29/32 31/32 1 1/16 1 1/8 1 3/16 1 3/8
Diameter of Bolt Circle
(inches)
2 5/8 3 1/4 3 1/2 3 7/8 4 1/2 5 5 7/8 6 5/8 7 1/4 7 7/8 9 1/4 10 5/8 13
Numbers of Bolts 4 4 4 4 4 4 8 8 8 8 8 12 12
Diameter of Bolts
(inches)
1/2 5/8 5/8 5/8 3/4 3/4 3/4 3/4 3/4 3/4 3/4 3/4 7/8
  • 1 inch = 25.4 mm
Piping Systems
ASME - American Society of Mechanical Engineers
ASME is one of the leading organizations in the world developing codes and standards.
ASTM Flanges - Hydrostatic Test Pressures
Flanged fittings and required hydrostatic test pressure.
Bronze Flanges - ASME/ANSI 150 lb
Flange diameters, thickness, bolt circles, numbers and diameters of bolts for ASME/ANSI B16.15 - Cast Bronze Threaded Fittings - 150 lb Bronze flanges with plain faces.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 300
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 300 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 400
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 400 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon and Stainless Steel Flanges - ASME/ANSI Class 600
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 600 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Carbon Steel Flanges - Group 1.1 Pressure and Temperature Ratings
Maximum temperature and pressure ratings of flanges conforming dimensions ASME B16.5 and materials specification ASTM A-105.
Carbon Steel Flanges - Pressure and Temperature Ratings
Maximum ratings for flanges conforming to ISO Standard 2229 dimensions and material specification AST-A-105.
Metal Alloys - Specific Heats
Specific heat of metal alloys like brass, bronze and more.
Metals and Alloys - Densities
Pipe Flanges and Gaskets - Dimensions
Gasket dimensions according ASME B16.5 Pipe Flanges and Flange Fittings.
PN Pressure Ratings for Flanges: Specifications & Standards
