Pressure (psig) and temperature ratings for steel pipe flanges and flanged fittings according the American National Standard ANSI B16.5 - 1988 Group 1.2:
Temperature (°C) | Working Pressure (bar) | ||||||
Class | |||||||
150 | 300 | 400 | 600 | 900 | 1500 | 2500 | |
-29 - 38 | 19.8 | 51.7 | 68.9 | 103.4 | 155 | 259 | 431 |
50 | 19.5 | 51.7 | 68.9 | 103.4 | 155 | 259 | 431 |
100 | 17.7 | 51.5 | 68.7 | 103.0 | 155 | 258 | 429 |
150 | 15.8 | 50.2 | 66.8 | 100.3 | 151 | 251 | 418 |
200 | 13.8 | 48.6 | 64.8 | 97.2 | 146 | 243 | 405 |
250 | 12.1 | 46.3 | 61.7 | 92.7 | 139 | 232 | 386 |
300 | 10.2 | 42.9 | 57.0 | 85.7 | 129 | 214 | 357 |
325 | 9.3 | 41.4 | 55.0 | 82.6 | 124 | 207 | 344 |
350 | 8.4 | 40.0 | 53.4 | 80.0 | 120 | 200 | 334 |
375 | 7.4 | 37.8 | 50.4 | 75.7 | 114 | 189 | 315 |
400 | 6.5 | 34.7 | 46.3 | 69.4 | 104 | 174 | 290 |
425 | 5.5 | 28.8 | 38.4 | 57.5 | 86.3 | 144 | 240 |
450 | 4.6 | 23.0 | 30.7 | 46.0 | 69.0 | 115 | 192 |
475 | 3.7 | 17.1 | 22.8 | 34.2 | 51.3 | 85.4 | 142 |
500 | 2.8 | 11.6 | 15.4 | 23.2 | 34.7 | 57.9 | 96.5 |
538 | 1.4 | 5.9 | 7.9 | 11.8 | 17.7 | 29.5 | 49.2 |
The values in this table apply to materials Group 1.2
For other Material Groups the Pressure-Temperature Ratings are different. Most carbon steels are only acceptable for temperatures below 800 F.
• Pressure Ratings of Pipes and Fittings
ASME - American Society of Mechanical Engineers
ASME is one of the leading organizations in the world developing codes and standards.
ASME/ANSI B16 Standards for Pipes and Fittings
The ASME B16 standards covers pipes and fittings in cast iron , cast bronze, wrought copper and steel.
ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 150 to 2500
Diameters and bolt circles for standard ASME B16.5 flanges - 1/4 to 24 inches - Class 150 to 2500.
ASTM Flanges - Hydrostatic Test Pressures
Flanged fittings and required hydrostatic test pressure.
Bronze Flanges - ASME/ANSI 150 lb
Flange diameters, thickness, bolt circles, numbers and diameters of bolts for ASME/ANSI B16.15 - Cast Bronze Threaded Fittings - 150 lb Bronze flanges with plain faces.
Carbon Steel Flanges - Group 1.1 Pressure and Temperature Ratings
Maximum temperature and pressure ratings of flanges conforming dimensions ASME B16.5 and materials specification ASTM A-105.
Carbon Steel Pipes - Pressure and Temperature Ratings, Imperial Units
Pressure (psig) and temperature (deg F) ratings for A-53 B and A-106 B, A333, A334 and API 5L carbon steel pipes - temperatures ranging 100 degF - 700 degF.
Carbon Steel Pipes - Pressure and Temperature Ratings, Metric Units
Pressure (kPa)> and temperature (degC) ratings of ASTM A-106, API 5L and ASTM A-53 Seamless Carbon Steel Pipes - temperatures ranging -29 degC - 450 degC.
Cast Iron Flanges - ASME/ANSI Class 125
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 125 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Flanges - API vs. ASME/ANSI
API and ASME/ANSI flanges - comparing dimensions and pressure ratings.
Steel Pipes - De-Rating vs. Temperature
Temperature derating factor for steel pipes.
Steel Tubes - Working Pressures vs. Size
Normal maximum working pressures for steel tubes - in psi and kPa.
Water Hammer
Rapidly closing or openingĀ valves - or starting stopping pumps - may cause pressure transients in pipelines known as surge or water hammer.
