minimum 0oF (-18oC)
ASME is one of the leading organizations in the world developing codes and standards.
The ASME Performance Test Codes provide standard directions and rules for conducting and reporting tests.
Maximum working pressure of carbon steel pipe at temperature 400oF.
Maximum temperature and pressure ratings of flanges conforming dimensions ASME B16.5 and materials specification ASTM A-105.
Pressure (psig) and temperature (deg F) ratings for A-53 B and A-106 B, A333, A334 and API 5L carbon steel pipes - temperatures ranging 100 degF - 700 degF.
Pressure (kPa)> and temperature (degC) ratings of ASTM A-106, API 5L and ASTM A-53 Seamless Carbon Steel Pipes - temperatures ranging -29 degC - 450 degC.
Maximum operating and bursting pressures of CPVC - Chlorinated Poly (Vinyl Chloride) - piping systems.
Commonly used standards for fiberglass pipes and their applications.
Materials approved for gas pipes.
Allowable wall stress in pipes according ASME M31.3.
Materials used in water distribution pipes.
Water service pipe lines extends from the potable water source to the interior of buildings.
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
