Fiberglass Pipes - common Standards
Some of the fiberglass related standards from the major standardization organizations:
ASME Standards
Fiberglass related standards from ASME - American Society of Mechanical Engineers:
ASTM Standards
Fiberglass related standards from ASTM International
  • ASTM C 581 - STANDARD PRACTICE FOR DETERMINING CHEMICAL RESISTANCE OF THERMOSETTING RESINS USED IN GLASS-FIBER-REINFORCED STRUCTURES INTENDED FOR LIQUID SERVICE
  • ASTM C 582 - STANDARD SPECIFICATION FOR CONTACT-MOLDED REINFORCED THERMOSETTING PLASTIC (RTP) LAMINATES FOR CORROSION RESISTANT EQUIPMENT
  • ASTM D 149 - STANDARD TEST METHOD FOR DIELECTRIC BREAKDOWN VOLTAGE AND DIELECTRIC STRENGTH OF SOLID ELECTRICAL INSULATING MATERIALS AT COMMERCIAL POWER FREQUENCIES
  • ASTM D 257 - TEST METHODS FOR DC RESISTANCE OR CONDUCTANCE OF INSULATING MATERIALS
  • ASTM D 638 - STANDARD TEST METHOD FOR TENSILE PROPERTIES OF PLASTICS
  • ASTM D 695M - TEST METHOD FOR COMPRESSIVE PROPERTIES OF RIGID PLASTICS (METRIC)
  • ASTM D 696 - STANDARD TEST METHOD FOR COEFFICIENT OF LINEAR THERMAL EXPANSION OF PLASTICS BETWEEN - 30 DEGREES C AND 30 DEGREES C WITH A VITREOUS SILICA DILATOMETER
  • ASTM D 790 - STANDARD TEST METHODS FOR FLEXURAL PROPERTIES OF UNREINFORCED AND REINFORCED PLASTICS AND ELECTRICAL INSULATING MATERIALS
  • ASTM D 792 - TEST METHODS FOR DENSITY AND SPECIFIC GRAVITY (RELATIVE DENSITY) OF PLASTICS BY DISPLACEMENT
  • ASTM D 1598 - STANDARD TEST METHOD FOR TIME-TO-FAILURE OF PLASTIC PIPE UNDER CONSTANT INTERNAL PRESSURE
  • ASTM D 1599 - STANDARD TEST METHOD FOR RESISTANCE TO SHORT-TIME HYDRAULIC PRESSURE OF PLASTIC PIPE, TUBING, AND FITTINGS
  • ASTM D 2105 - STANDARD TEST METHOD FOR LONGITUDINAL TENSILE PROPERTIES OF "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) PIPE AND TUBE
  • ASTM D 2143 - STANDARD TEST METHOD FOR CYCLIC PRESSURE STRENGTH OF REINFORCED, THERMOSETTING PLASTIC PIPE
  • ASTM D 2290 - STANDARD TEST METHOD FOR APPARENT HOOP TENSILE STRENGTH OF PLASTICOR REINFORCED PLASTIC PIPE BY SPLIT DISK METHOD
  • ASTM D 2310 - STANDARD CLASSIFICATION FOR MACHINE-MADE "FIBERGLASS" (GLASS-FIBER REINFORCED THERMOSETTING-RESIN) PIPE
  • ASTM D 2412 - STANDARD TEST METHOD FOR DETERMINATION OF EXTERNAL LOADING CHARACTERISTICS OF PLASTIC PIPE BY PARALLEL-PLATE LOADING
  • ASTM D 2444 - TEST METHOD FOR DETERMINATION OF THE IMPACT RESISTANCE OF THERMOPLASTIC PIPE AND FITTINGS BY MEANS OF A TUP (FALLING WEIGHT)
  • ASTM D 2583 - STANDARD TEST METHOD FOR INDENTATION HARDNESS OF RIGID PLASTICS BY MEANS OF A BARCOL IMPRESSOR
  • ASTM D 2584 - STANDARD TEST METHOD FOR IGNITION LOSS OF CURED REINFORCED RESINS
  • ASTM D 2924 - STANDARD TEST METHOD FOR EXTERNAL PRESSURE RESISTANCE OF "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) PIPE
  • ASTM D 2925 - STANDARD TEST METHOD FOR BEAM DEFLECTION OF "FIBERGLASS" (GLASS- FIBER-REINFORCED THERMOSETTING RESIN) PIPE UNDER FULL BORE FLOW
  • ASTM D 2992 - STANDARD PRACTICE FOR OBTAINING HYDROSTATIC OR PRESSURE DESIGN BASIS FOR "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) PIPE AND FITTINGS
  • ASTM D 2996 - STANDARD SPECIFICATION FOR FILAMENT-WOUND "FIBERGLASS" (GLASS- FIBER-REINFORCED THERMOSETTING-RESIN) PIPE
  • ASTM D 2997 - STANDARD SPECIFICATION FOR CENTRIFUGALLY CAST "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) PIPE
  • ASTM D 3262 - STANDARD SPECIFICATION FOR "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) SEWER PIPE
  • ASTM D 3517 - STANDARD SPECIFICATION FOR "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) PRESSURE PIPE
  • ASTM D 3567 - STANDARD PRACTICE FOR DETERMINING DIMENSIONS "FIBERGLASS" (GLASS- FIBER-REINFORCED THERMOSETTING RESIN) PIPE AND FITTINGS
  • ASTM D 3615 - CHEMICAL RESISTANCE OF THERMOSET MOLDING COMPOUNDS
  • ASTM D 3681 - STANDARD TEST METHOD FOR CHEMICAL RESISTANCE OF "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) PIPE IN A DEFLECTED CONDITION
  • ASTM D 3754 - STANDARD SPECIFICATION FOR "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) SEWER AND INDUSTRIAL PRESSURE PIPE
  • ASTM D 3840 - STANDARD SPECIFICATION FOR "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) PIPE FITTINGS FOR NONPRESSURE APPLICATIONS
  • ASTM D 4024 - STANDARD SPECIFICATION FOR MACHINE MADE "FIBERGLASS" (GLASS-FIBER REINFORCED THERMOSETTING RESIN) FLANGES
  • ASTM D 4161 - STANDARD SPECIFICATION FOR "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) PIPE JOINTS USING FLEXIBLE ELASTOMERIC SEALS
  • ASTM D 5365 - STANDARD TEST METHOD FOR LONG-TERM RING-BENDING STRAIN OF "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) PIPE
  • ASTM D 5421 - STANDARD SPECIFICATION FOR CONTACT MOLDED "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING RESIN) FLANGES
  • ASTM D 5677 - STANDARD SPECIFICATION FOR FIBERGLASS (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) PIPE AND PIPE FITTINGS, ADHESIVE BONDED JOINT TYPE, FOR AVIATION JET TURBINE FUEL LINES
  • ASTM D 5685 - STANDARD SPECIFICATION FOR "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING-RESIN) PRESSURE PIPE FITTINGS
  • ASTM D 6041 - STANDARD SPECIFICATION FOR CONTACT-MOLDED "FIBERGLASS" (GLASS-FIBER-REINFORCED THERMOSETTING RESIN) CORROSION RESISTANT PIPE AND FITTINGS
  • ASTM E 228 - LINEAR THERMAL EXPANSION OF SOLID MATERIALS WITH A VITREOUS SILICA DILATOMETER
  • ASTM F 1173 - STANDARD SPECIFICATION FOR THERMOSETTING RESIN FIBERGLASS PIPE SYSTEMS TO BE USED FOR MARINE APPLICATIONS
AWWA Standards
Fiberglass related standards from AWWA - American Water Works Association
  • AWWA C950-01 - Fiberglass Pressure Pipe
  • AWWA D120-84 (R89) - Thermosetting Fiberglass-Reinforced Plastic Tanks
  • AWWA F101-02 - Contact-Molded, Fiberglass-Reinforced Plastic Wash Water Troughs and Launders
  • AWWA F102-02 - Matched-Die-Molded, Fiberglass-Reinforced Plastic Weir Plates, Scum Baffles, and Mounting Brackets
BSi Standards
Fiberglass related standards from BSi - British Standards institute
  • BS 5480 - Specification for glass reinforced plastics (GRP) pipes, joints and fittings for use for water supply or sewerage
  • BS 6464 - Specification for reinforced plastics pipes, fittings and joints for process plants
  • BS 7159 - Code of practice for design and construction of glass-reinforced plastics (GRP) piping systems for individual plants or sites
  • BS 8010-2.5 - Code of practice for pipelines - Pipelines on land: design, construction and installation - Glass reinforced thermosetting plastics
DIN Standards
Fiberglass related standards from DIN - Deutsches Institut für Normung
  • DIN 53393 - Testing of Textile Glass-reinforced Plastics; Behavior to the Effect of Chemicals
  • DIN 53758 - Testing of plastics articles; determination of the effect of internal pressure on hollow objects by short-time test
  • DIN 53768 - Determination by extrapolation of the long-term behavior of glass fiber reinforced plastics
  • DIN 53769-1 - Testing of glass fiber reinforced plastics pipes; determination of the longitudinal shear strength of type B pipe fittings
  • DIN 53769-2 - Testing of glass fiber reinforced plastics pipes; long-term hydrostatic pressure test
  • DIN 53769-3 - Testing of glass fiber reinforced plastics pipes; determination of initial and long-term ring stiffness
  • DIN 53769-6 - Testing of glass fiber reinforced plastics pipes; Testing of pipes and fittings under pulsating internal pressure
  • DIN EN 59 - Glass Reinforced Plastics; Measurement of Hardness by Means of a Barcol Impressor
  • DIN EN 637 - Plastics piping systems - Glass-reinforced plastics components - Determination of the amounts of constituents using the gravimetric method
  • DIN EN 705 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Methods for regression analyses and their use
  • DIN EN 761 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of the creep factor under dry conditions
  • DIN EN 1393 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes; Determination of initial longitudinal tensile properties
  • DIN EN 1447 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of long-term resistance to internal pressure
  • DIN EN 1448 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) components - Test methods to prove the design of rigid locked socket- and -spigot joints with elastomeric seals
  • DIN EN 1449 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) components - Test methods to prove the design of a cemented socket- and -spigot joints
  • DIN EN 1450 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) components - Test methods to prove the design of bolted flange joints
ISO Standards
Fiberglass related standards from ISO - International Organization for Standardization
  • ISO 178 - Plastics - Determination of flexural properties
  • ISO 527-4 - Plastics - Determination of tensile properties - Part 4: Test conditions for isotropic and orthotropic fibre-reinforced plastic composites
  • ISO 7370 - Glass fiber reinforced thermosetting plastics (GRP) pipes and fittings; Nominal diameters, specified diameters and standard lengths
  • ISO 7510 - Plastics piping systems - Glass-reinforced plastics (GRP) components - Determination of the amounts of constituents using the gravimetric method
  • ISO 7684 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Determination of the creep factor under dry conditions
  • ISO 10466 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes - Test method to prove the resistance to initial ring deflection
  • ISO 10928 - Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Methods for regression analysis and their use
  • ISO/TR 10465-1 - Underground installation of flexible glass-reinforced thermosetting resin (GRP) pipes; part 1: installation procedures
  • ISO/TR 10465-2 - Underground installation of flexible glass-reinforced thermosetting resin (GRP) pipes - Part 2: Comparison of static calculation methods
  • ISO/TR 10465-3 - Underground installation of flexible glass-reinforced thermosetting resin (GRP) pipes - Part 3: Installation parameters and application limits
Codes and Standards
ABS, PE, PVC, Fiberglass and Steel Pipes - Supports
Maximum distance between supports for ABS, PE, PVC, Fiberglass and Steel Pipes.
Fiberglass Pipes and Temperature Limits
Temperature ranges for fiberglass Epoxy, Furan, Phenolic, Polyester and Vinyl Ester pipes.
Plastics - Abbreviations
Commonly used plastic abbreviations.
Plastics - Recycling Codes and Labeling
Symbol codes and labeling used for recycling plastic products like bottles, containers and packagin.
