The diagrams below can be used for design of sewage and wastewater gravity conveying systems.
Sewage Pipe Capacity - Imperial units - gpm
Sewage Pipe Capacity - SI Units - liter per second
Note! - the charts are based on clean plastic pipes - calculated with the Manning formula, roughness coefficient 0.015 and fill 50%.
@Example - Capacity of a Sewer Pipe
The capacity of a 4 inch sewer pipe with decline 0.5% is aprox. 25 gpm (1.6 liter/s).
- 1 gal (US)/min = 6.30888×10-5 m3/s = 0.227 m3/h = 0.06309 dm3(liter)/s = 2.228×10-3 ft3/s = 0.1337 ft3/min = 0.8327 Imperial gal (UK)/min
Decline and Slope
Calculate between decline and slope units
d = 8.33 s(in/ft)
= 100 s(ft/ft)
= 100 s(m/m)
= s(ft/100ft) (1)
d = decline (%)
s = slope
Example - % Decline
1/8 in/ft slope can be transformed to % decline as
d = 8.33 (1/8 in/ft)
= 1.04 %
• Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
ASTM B306 Copper Tubes for Drain, Waste and Vent - Dimensions and Working Pressures
California Pipe Flow Metering Method
Calculate the discharge length from the open end of a partially filled horizontal pipe.
Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipes.
Cleanouts in Draining Systems
Cleanouts provides access to the sewer for rodding.
DFU - Drainage Fixture Units
DFU are used to calculate the drainage flow from fixtures and the required capacities of sewer service systems.
Ditch Filling Materials - Densities
Weight or density of ditch filling materials.
Drain Pipes and Vent Stacks
Drain pipes and vent stack sizing.
Drain Waste and Vent Pipes - Hanger Spacing
Support of Drain Waste and Vent - DWV - pipes.
Drains and Sewers - Capacities vs. Size
Drainage Fixture Units (DFU) connected to building drains and sewers.
Fiberglass Pipes - common Standards
Commonly used standards for fiberglass pipes and their applications.
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures
Manning's Formula and Gravity Flow
Calculate cross-sectional average velocity flow in open channels.
Pipes - Relative Capacity
Relative capacity between larger and smaller pipes.
Sanitary Drainage Systems - Volume Flow
Calculate expected volume flow load in sanitary drainage systems.
Septic Systems
Septic systems handles waste from drain systems.
Sewage Sludge - Viscosities
Viscosity of sewage sludge vs. content of solids.
Storm-Water Conductors
Roof drain capacities.
Storm-Water Runoff Coefficients vs. Surface
Storm-water runoff coefficients for various surfaces
Trap Sizes vs. Fixture Units
No. of fixture units and required trap size.
Waste Water Piping - Flow Capacitiy vs. Dimension
In sewage piping and pumping systems the fluid flow rate must be kept within certain limits to avoid operating problems.
