DFU - Drainage Fixture Units
DFU (Drainage Fixture Unit Values) is defined by the the Uniform Plumbing Code (UPC) and can be used to determine required drainage capacities from fixtures and their service systems.
A Fixture Unit is not a flow rate unit but a design factor based on the rate of discharge, time of operation and frequency of use of a fixture. A fixture unit is equal to one cubic foot of water drained in an 1 1/4 pipe over one minute (≈ 7.48 U.S. gpm, ≈ 0.47 l/s).
Individual Appliance, Appurtenance or FixtureMinimum Size of TrapDrainage Fixture Unit Values
(DFU)
Typical Values used in Europe
(inch)Private InstallationsPublic Installations(l/s)
Automatic clothes washers, commercial 2 3
Automatic clothes washers, residential 2 2
Bathroom (water closet, lavatory, bidet and tub or shower) 3 6 -
Bathtub 1 1/2 2 2 0.9
Bidet 1 1/4 1   0.3
Bidet 1 1/2 2
Clothes Washer 2 3 3
Dental unit, cuspidor 1 1/4 1
Dental lavatory 1 1/2 1
Dishwashing machine, domestic 1 1/2 2 2 0.6
Drinking fountain 1 1/4 0.5 0.5 0.1
Floor drain, 3" 3 6 6
Floor drain, 4" 4 8 8 2
Food waste disposer 2 3
Shower 2 2 2 0.4
Laundry tub 1 1/2 2 2
Lavatory 1 1/4 1 1
Bar sink 1 1/2 1
Kitchen sink, domestic 1 1/2 2 2
Laundry sink 1 1/2 2 2
Mobile home, trap 3 12
Service or mop basin 2   3
Sink, bar 1 1/2 1 0.3
Sink, clinical 1 1/2 2
Sink, commercial with food waste 2 3
Sink, kitchen domestic 1 1/2 2 2 0.6
Sink, laundry 1 1/2 2 2
Sink, service mop basin 2 3 0.9
Urinal 2 2 2 0.3
Washfountain 1 1/2 2
WC - Water Closet, gravity tank 3 3 4 1.8
WC - Water Closet, flushometer tank, valve 3 3 4
Water cooler 1 1/4 0.5 0.5
Fixture Units are used in plumbing design for both water supply (WFSU) and waste water (DFU).
Since the fixtures in a system are never used all at the same time, the total units (capacity) achieved by adding the numbers for all fixtures must be compensated for intermittent use if we want a realistic estimate of the total drainage load.
Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipes.
Cleanouts in Draining Systems
Cleanouts provides access to the sewer for rodding.
Cold Water Dwellings - Storage Capacities
Required cold water dwelling storage capacity - commonly used fixtures and types of buildings.
Cold Water Storage per Occupant
Cold water storage for occupants in common types of buildings as factories, hospitals, houses and more
Draining Systems - Main Vents
Vents in draining systems protects traps against pressure differences that could cause them to siphon or blow out .
Drains and Sewers - Capacities vs. Size
Drainage Fixture Units (DFU) connected to building drains and sewers.
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures
Plumbing Codes
Plumbing or sanitation codes are a set of rules and regulations imposed by cities, counties or states.
Sanitary Drainage Systems - Volume Flow
Calculate expected volume flow load in sanitary drainage systems.
Trap Sizes vs. Fixture Units
No. of fixture units and required trap size.
