The relationship between volume flow and fixture units is not constant, but varies with the number of fixture units. A Fixture Unit is not a flow rate unit but a design factor based on the rate of discharge, time of operation and frequency of use of a fixture. A fixture unit is equal to one cubic foot of water drained in an 1 1/4 pipe over one minute (≈ 7.48 US gpm, ≈ 0.47 l/s).
Maximum Drainage Fixture Units (DFU) in Stacks and Horizontal Fixture Branches
Pipe SizeMaximum Drainage Fixture Units (DFU)
Horizontal fixture branchStacks3) less than three stories in heightStacks more than three stories high
NPS
(inches)
DN
(mm)
Total for stackTotal for one story
1 1/20) 40 3 4 8 2
20) 50 6 10 24 6
2 1/20) 65 12 20 42 9
3 80 201) 481) 722) 201)
4 100 160 240 500 90
5 125 360 540 1100 200
6 150 620 960 1900 350
0) No water closet permitted
1) Maximum two water closets
2) Maximum six water closets
3) Stacks - vertical runs of plumbing waste or drainage lines
The values are based on the major US plumbing codes.
Maximum  Drainage Fixture Units (DFU) in Building Drains and Building Drain Branches from Stacks
Slope (in/ft (cm/m))
NPS
(inches)
DN
(mm)
1/4 (2.1)1/2 (4.2)
20) 50 21 26
2 1/20) 65 24 31
3 80 421) 501)
4 100 216 250
5 125 480 575
6 150 840 1000
Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
ASTM B306 Copper Tubes for Drain, Waste and Vent - Dimensions and Working Pressures
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipes.
Cleanouts in Draining Systems
Cleanouts provides access to the sewer for rodding.
DFU - Drainage Fixture Units
DFU are used to calculate the drainage flow from fixtures and the required capacities of sewer service systems.
Drain Pipes and Vent Stacks
Drain pipes and vent stack sizing.
Drain Waste and Vent Pipes - Hanger Spacing
Support of Drain Waste and Vent - DWV - pipes.
Draining Systems - Main Vents
Vents in draining systems protects traps against pressure differences that could cause them to siphon or blow out .
Drains and Sewers - Capacities vs. Size
Drainage Fixture Units (DFU) connected to building drains and sewers.
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures
Horizontal Drainage Pipe - Required Slopes
Minimum pitch of horizontal drainage pipes.
Plumbing Codes
Plumbing or sanitation codes are a set of rules and regulations imposed by cities, counties or states.
Sanitary Drainage Systems - Volume Flow
Calculate expected volume flow load in sanitary drainage systems.
Septic Systems
Septic systems handles waste from drain systems.
Trap Sizes vs. Fixture Units
No. of fixture units and required trap size.
Waste Water Piping - Flow Capacitiy vs. Dimension
In sewage piping and pumping systems the fluid flow rate must be kept within certain limits to avoid operating problems.
Water Supply due to Fixtures Water Requirements
Supply requirements for common fixtures.
Water Supply Fixture Units - WSFU vs. GPM and Liters/sec
Converting WSFU - Water Supply Fixture Units - to GPM.
