Building Officials and Code Administrators International (BOCA)
The codes are adopted and altered by the local authorities to fit local needs.
Throughout the world different countries and jurisdictions have their local or common (as within EU) set of codes for different type of work. For the engineer it is always necessary to check and adapt to the local regime.
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
International organization for professionals skilled in the design, specification and inspection of plumbing systems.
DFU are used to calculate the drainage flow from fixtures and the required capacities of sewer service systems.
Drain pipes and vent stack sizing.
Supply requirements for common fixtures.
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
