Fixture Water Consumption and Required Water Supply
Each fixture in a water supply system represents a certain demand of water. Supply requirement for common fixtures:
Water Supply Flow and Pressure due to Fixtures Water Requirements
FixtureFlow rateMinimum Supply Pressure
(gpm)(l/min)(psi)(kPa)
Aspirator 2.5 10 8 55
Bathtub faucet 5 19 8 55
Bidet 2 7.5 4 28
Combination fixture 4 15 8 55
Dish washing machine 4 15 8 55
Drinking fountain jet 0.75 3 8 55
Hose bib or sillcock, 1/2" 5 19 8 55
Laundry faucet 1/2" 5 19 8 55
Laundry machine 4 15 8 55
Lavatory faucet, ordinary 2 7.5 8 55
Lavatory faucet, self closing 2.5 10 8 55
Shower head 5 19 8 55
Shower, temperature controlled 3 10 20 138
Sink faucet 3/8", 1/2" 4.5 17 8 55
Sink faucet 3/4" 6 23 8 55
Urinal flush valve 15 56 15 110
Water closet with flush valve 35 132 25 170
Water closet with gravity tank 2.5 10 8 55
Water closet with close coupled tank, ballcock 3 11 8 55
Adding up the numbers to cover all fixtures in a system would give the total demand if all fixtures were used at the same time. This is  almost never realistic for a supply system. Reasonable estimates must be made based on simultaneously demand from the fixtures.
Example - Required Water Supply
For a water supply system the summarized theoretical water flow for all fixtures is 10 l/s. The largest fixture in the system requires 0.4 l/s.
Based on the diagram above the expected total water flow in the system will be aprox. 1.1 l/s.
Water Systems
Cold Water Dwellings - Storage Capacities
Required cold water dwelling storage capacity - commonly used fixtures and types of buildings.
Cold Water Storage per Occupant
Cold water storage for occupants in common types of buildings as factories, hospitals, houses and more
Farm Livestock - Animals and Water Consumption
Average daily water consumption of various farm animals, including cattle, horses, sheep, and poultry.
Fixtures - Hot Water Content
Content of hot water in some common used fixtures - basins, sinks and baths.
Fixtures Hot Water Consumption
Hot water consumption of fixtures like basins, showers, sinks and baths.
Hot Water Circulation System - Return Pipes
Hot water can be circulated through a return pipe if it's instantly required at the fixtures.
Plumbing Codes
Plumbing or sanitation codes are a set of rules and regulations imposed by cities, counties or states.
Required Water Supply to Public Buildings
Water consumption and supply to public buildings.
Water Consumption and Activities
Typical human activities and average water consumption
Calculating expected demand for water supply service lines.
Water Supply Fixture Units - WSFU vs. GPM and Liters/sec
Converting WSFU - Water Supply Fixture Units - to GPM.
Yard Fixtures - Water Consumption
Water consumption in garden fixtures.
