Yard Fixtures - Water Consumption
Water consumption in garden fixtures
Garden Fixture | Aprox. Water Consumption | |
(gpm) | (l/s) | |
Garden Hose - 1/2" | 3 | 0.2 |
Garden Hose - 3/4" | 6 | 0.4 |
Sprinkle - Lawn | 3-7 | 0.2 - 0.5 |
• Water Systems
Hot and cold water service systems - design properties, capacities, sizing and more.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Domestic Service Water Supply Systems
Introduction to general design of domestic service water supply systems - with pressurized or gravity tanks.
Farm Livestocks - Water Consumption
Farming and animals required water supply.
Hoses - Pressure Loss vs. Water Flow
Pressure loss in hoses due to water flow and friction.
Hoses - Water Volume Discharge Flow vs. Pressure
Water discharge through hoses - pressure ranging 10 - 200 psi (0.75 - 14 bar).
Hot and Cold Water Pipes Sizing
Recommended dimensions hot and cold water pipes.
Water - Human Activity and Consumption
Activity and average water consumption
Water Supply - Cross-Contamination Control
It is fundamental to keep the potable water in the water supply systems uncontaminated.
Water Supply due to Fixtures Water Requirements
Supply requirements for common fixtures.
Water Supply Lines - Sizing
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
