Hoses - Water Volume Discharge Flow vs. Pressure
Hose - Water Discharge - Imperial Units
Water discharge through 100 feet hoses - at pressures ranging 10 - 200 psi:
Download and print Hose Water Discharge Chart
  • 1 psi = 6.9 kPa = 0.069 bar
  • 1 ft (foot) = 0.3048 m
  • 1 gal (US)/min =6.30888x10-5 m3/s = 0.227 m3/h
Hose - Water Discharge - Metric Units
Water discharge through 30 m hoses - at pressures ranging 0.75 - 14 bar:
Hoses - Internal Diameter vs. Nominal Diameter
Hose Nominal Diameter
(inches)
Internal Diameter
(inches)
1/8 0.125
3/16 0.1875
1/4 0.25
5/16 0.3125
3/8 0.375
7/16 0.4375
1/2 0.5
5/8 0.625
3/4 0.75
7/8 0.875
1 1
1 1/4 1.25
1 1/2 1.5
2 2
2 1/2 2.5
3 3
3 1/2 3.5
4 4
5 5
6 6
Water Systems
Hot and cold water service systems - design properties, capacities, sizing and more.
Hoses - Pressure Loss vs. Water Flow
Pressure loss in hoses due to water flow and friction.
Jet Propulsion
Calculate the propulsive discharge force or thrust induced by an incompressible jet flow.
Nozzles - Water Discharge Capacities
Discharge capacities of water nozzles.
Open Horizontal Pipes - Discharge Length vs. Volume Flow
Discharge length vs. volume flow from water filled horizontal pipes.
Vertical Pipes - Discharge Height vs. Volume Flow
Volume flow and discharge height from vertical water pipes.
Yard Fixtures - Water Consumption
Water consumption in garden fixtures.
