Hot and cold water service systems - design properties, capacities, sizing and more.
Pressure loss in hoses due to water flow and friction.
Water discharge through hoses - pressure ranging 10 - 200 psi (0.75 - 14 bar).
Calculate the propulsive discharge force or thrust induced by an incompressible jet flow.
Calculate liquid velocity, volume flow and draining time when emptying a container.
Discharge capacities of water nozzles.
Discharge length vs. volume flow from water filled horizontal pipes.
Water velocities in pipes and tubes should not exceed certain limits.
