The height from the surface to the outlet aperture in a water filled container is 3 m. The aperture is sharp edged with diameter 0.1 m. The discharge coefficient can be calculated as
Cd = 0.62 0.97
= 0.6
The area of the aperture can be calculated as
A = π ((0.1 m) / 2)2
= 0.008 m2
The volume flow through the aperture can be calculated as
V = 0.6(0.008 m2) (2 (9.81 m/s2) (3 m))1/2
= 0.037 m3/s
For height 1.5 m the volume flow is 0.026 m3/s. For height 0.5 m the volume flow is 0.015 m3/s.
This calculator is based on eq. (1b) and can be used to estimate the volume flow and time used to drain a container or tank through an aperture.
The calculator divides the container in "slices" and makes an iterative average calculation for each slice. The accuracy of the calculation can be increased by increasing the number of slices.
Note! - the flow is reduced and the time is increased with reduced height.
Outlet velocity can be expressed as
v = Cv (2 g H)1/2 (2a)
Distance s can be expressed as
s = 2 (H h)1/2 (2b)
Volume flow can be expressed as
V = Cd A (2 g H)1/2 (2c)
Reaction force can be expressed as
F = ρ V v (2d)
ρ = density (kg/m3) (water 1000 kg/m3)
V = 2/3 Cd b (2 g)1/2 (H23/2 - H13/2) (3a)
b = width of aperture (m)
v = Cv (2 (g H + p / ρ))1/2 (4a)
p = excess pressure in container or tank (N/m2, Pa)
V = Cd A (2 (g H + p / ρ))1/2 (4b)
Conservation of energy in a non-viscous, incompressible fluid at steady flow.
Volume in US gallons and liters.
The Mechanical Energy Equation compared to the Extended Bernoulli Equation.
Discharge length vs. volume flow from water filled horizontal pipes.
Volume flow and discharge height from vertical water pipes.
