Open Horizontal Pipes - Discharge Length vs. Volume Flow
Discharge volume and maximum length for horizontal pipes.
  • 1 gal (US)/min =6.30888×10-5 m3/s = 0.227 m3/h = 0.06309 dm3(litre)/s = 2.228×10-3 ft3/s = 0.1337 ft3/min = 0.8327 Imperial gal (UK)/min
  • 1 in (inch) = 25.4 mm = 2.54 cm = 0.0254 m = 0.08333 ft
Example - Horizontal Pipe and Length of Water Discharge
If 100 gpm water is discharged from a 2 1/2" horizontal pipe
- the discharge length can be estimated from the chart above to approximately 13 inches.
Example - Estimating Volume Flow with Discharge Length
The volume flow  from a pipe can be estimated by measuring the horizontal length of the discharging flow.
If the discharge length from a 2 1/2" horizontal pipe is measured to 13 inches
- the volume flow discharged can be estimated to approximately 100 gpm.
Flow Measurements
Water Systems
Hoses - Water Volume Discharge Flow vs. Pressure
Water discharge through hoses - pressure ranging 10 - 200 psi (0.75 - 14 bar).
Jet Propulsion
Calculate the propulsive discharge force or thrust induced by an incompressible jet flow.
Liquid Flow from Containers - Emptying Time
Calculate liquid velocity, volume flow and draining time when emptying a container.
Nozzles - Water Discharge Capacities
Discharge capacities of water nozzles.
Vertical Pipes - Discharge Height vs. Volume Flow
Volume flow and discharge height from vertical water pipes.
Water Systems - Maximum Flow Velocities
Water velocities in pipes and tubes should not exceed certain limits.
