Domestic Service Water Supply Systems
The purpose with a domestic service water supply system is to provide consumers with enough hot and cold water.
In old buildings it is common with gravity storage tanks on the top floor of the building. More commonly used in new systems are pressurized tanks and supply pumps.
Domestic Water Supply with Gravity Tank
Domestic water supply system with gravity tank:
For proper operation of the system the gravity tank is located at least 30 ft or 10 m above the highest outlet or consumer. In taller buildings pressure reducing valves are required in the lowest floors before the fittings.
The volume of a gravity tank must be designed to compensate for limited capacity of a supply line. The tank fills up when the consumption of hot and cold water is lower than the capacity of the supply line - and the tank is emptied when the consumption is higher than the capacity of the supply line.
A drawback with the open gravity tank on the top floor is the potential danger of freezing during winter conditions. Huge tanks will also influence on the construction of the building.
Domestic Water Supply with a Pressurized Tank
Domestic water supply system with pressurized tank:
The pressurized tank is partly filled with air (or gas) behind a membrane. The air compensates for pressure variations during consumption and when supply pump starts and stops.
A pressurized tank has a limited compensating capacity for the shortage in a main supply line.
Estimating Required Buffer Tank Capacity
You are free to use the template bellow as a tool to estimate required buffer capacity in a water supply system. Log in to your Google Account to make your own copy to modify of the template. Alternatively - you can also save the Google Spreadsheet to your computer as a xls file.
Water Systems
Cold Water Dwellings - Storage Capacities
Required cold water dwelling storage capacity - commonly used fixtures and types of buildings.
Cold Water Storage per Occupant
Cold water storage for occupants in common types of buildings as factories, hospitals, houses and more
Domestic Hot Water Heaters - Sizing
Domestic Hot-Water sizing equations - heating capacity, recovery rate and power supply.
Domestic Hot Water Service Systems - Design Procedures
Design procedures for domestic hot water service systems.
Domestic Water Supply - Lime Deposits
Lime deposited vs. temperature and water consumption.
Fixtures Hot Water Consumption
Hot water consumption of fixtures like basins, showers, sinks and baths.
Hot and Cold Water Pipes Sizing
Recommended dimensions hot and cold water pipes.
Hot Water Circulation System - Return Pipes
Hot water can be circulated through a return pipe if it's instantly required at the fixtures.
Legionella
The Legionella Pneumophila bacterium thrives in water supply systems and air conditioning systems - and may cause the Legionnairs disease.
Required Water Supply to Public Buildings
Water consumption and supply to public buildings.
Water Consumption and Activities
Typical human activities and average water consumption
Water Distribution Pipes - Materials
Materials used in water distribution pipes.
Water Service Pipe Lines
Water service pipe lines extends from the potable water source to the interior of buildings.
Water Supply - Cross-Contamination Control
It is fundamental to keep the potable water in the water supply systems uncontaminated.
Water Supply Systems - Impurity Limits
Typiclal limits for impurities in drinking water.
Yard Fixtures - Water Consumption
Water consumption in garden fixtures.
