The WSFU (Water Supply Fixture Units) is defined by the Uniform Plumbing Code (UPC) and can be used to determine water supply to fixtures and their service systems.
Water Supply vs. Fixture Units
Individual FixturesMinimum Fixture Branch Pipe SizeWater Supply Fixture Units
WSFU
(inch)Private InstallationsPublic Installations
Bathtub 1/2 4 4
Bathtub with 3/4" fill valve 3/4 10 10
Bidet 1/2 1
Combination sink and tray 1/2
Dishwasher, domestic 1/2 1.5 1.5
Drinking fountain 1/2 0.5 0.5
Hose bibbs 1/2 2.5 2.5
Laundry, 1 - 3 compartments 1/2
Lavatory 1/2 1 1
Bar sink 1/2 1 2
Clinic fauce sink 1/2 3
Kitchen sink, domestic 1/2 1.5 1.5
Laundry sink 1/2 1.5 1.5
Service or mop basin 1/2 1.5 3
Sinks, flushing rim 3/4
Sinks, service 1/2
Washup basin 1/2 2
Shower, single head 1/2 2 2
Urinal, flush tank 1/2 2 2
Urinal, flushometer valve 3/4
Wall hydrant 1/2
Wash fountain 3/4 4
Water closet, gravity flush tank 1/2 2.5 2.5
Water closet, flushometer valve 1 2.5 2.5
Water cooler 1/2 0.5 0.5
  • 1 WSFU = 1 GPM = 3.79 liter/min
  • 1 in = 25.4 mm
Note that this conversion is only true for one or a few fixtures. Since all fixtures in a system are never used at the same time, the total units achieved by adding the numbers for all fixtures must be compensated for their intermittent use.
For supply pipe lines this is taken care of in the sizing tables.
For manifolds or special equipments sizing, a formula or a table can be used.
Water Systems
Cold Water Dwellings - Storage Capacities
Required cold water dwelling storage capacity - commonly used fixtures and types of buildings.
Cold Water Storage per Occupant
Cold water storage for occupants in common types of buildings as factories, hospitals, houses and more
DFU - Drainage Fixture Units
DFU are used to calculate the drainage flow from fixtures and the required capacities of sewer service systems.
Domestic Hot Water Service Systems - Design Procedures
Design procedures for domestic hot water service systems.
Draining Systems - Main Vents
Vents in draining systems protects traps against pressure differences that could cause them to siphon or blow out .
Drains and Sewers - Capacities vs. Size
Drainage Fixture Units (DFU) connected to building drains and sewers.
Farm Livestock - Animals and Water Consumption
Average daily water consumption of various farm animals, including cattle, horses, sheep, and poultry.
Fixtures - Hot Water Content
Content of hot water in some common used fixtures - basins, sinks and baths.
Hoses - Pressure Loss vs. Water Flow
Pressure loss in hoses due to water flow and friction.
Hot and Cold Water Pipes Sizing
Recommended dimensions hot and cold water pipes.
Hot Water Circulation System - Return Pipes
Hot water can be circulated through a return pipe if it's instantly required at the fixtures.
Hot Water Consumption vs. Occupants
Consumption of hot water per person or occupant.
Plumbing Codes
Plumbing or sanitation codes are a set of rules and regulations imposed by cities, counties or states.
Required Water Supply to Public Buildings
Water consumption and supply to public buildings.
Water Distribution Pipes - Materials
Materials used in water distribution pipes.
Calculating expected demand for water supply service lines.
Water Supply - Cross-Contamination Control
It is fundamental to keep the potable water in the water supply systems uncontaminated.
Water Supply Fixture Units - WSFU vs. GPM and Liters/sec
Converting WSFU - Water Supply Fixture Units - to GPM.
Water Supply Lines - Sizing
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
Yard Fixtures - Water Consumption
Water consumption in garden fixtures.
