Draining Systems - Main Vents
Vents protects traps against pressure differences that could cause them to siphon or blow out, leaving occupants unprotected against smell and potential contaminants from the sewer system.
Pipe Size
(in)
Max. Drainage Fixture Units
(DFU)
1 1/4 1
1 /1/2 81)
2 24
2 1/2 48
3 84
4 256
1) No water closets permitted
  • at least one vent should terminate through the roof
  • air admittance valves within the building may be permitted (check local authority)
  • terminating vents in side wall may be permitted (check local authority)
Dimensions of Pipes and Tubes
Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipes.
Cleanouts in Draining Systems
Cleanouts provides access to the sewer for rodding.
DFU - Drainage Fixture Units
DFU are used to calculate the drainage flow from fixtures and the required capacities of sewer service systems.
Drain Pipes and Vent Stacks
Drain pipes and vent stack sizing.
Drains and Sewers - Capacities vs. Size
Drainage Fixture Units (DFU) connected to building drains and sewers.
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures
Horizontal Drainage Pipe - Required Slopes
Minimum pitch of horizontal drainage pipes.
Sanitary Drainage Systems - Volume Flow
Calculate expected volume flow load in sanitary drainage systems.
Septic Systems
Septic systems handles waste from drain systems.
Trap Sizes vs. Fixture Units
No. of fixture units and required trap size.
Waste Water Piping - Flow Capacitiy vs. Dimension
In sewage piping and pumping systems the fluid flow rate must be kept within certain limits to avoid operating problems.
Water Supply Fixture Units - WSFU vs. GPM and Liters/sec
Converting WSFU - Water Supply Fixture Units - to GPM.
