Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipe and fittings:
Service Cast Iron
Service Cast Iron Soil Pipes - Dimensions
Size
(in)
Inside Diameter of Hub
(in)
Outside Diameter of Barrel
(in)
Inside Diameter barrel
(in)
2 2.94 2.30 1.96
3 3.94 3.30 2.96
4 4.94 4.30 3.94
5 5.94 5.30 4.94
6 6.94 6.30 5.94
8 9.25 8.38 7.94
10 11.38 10.50 9.94
12 13.50 12.50 11.94
Extra Heavy Cast Iron
Extra Heavy Cast Iron Soil Pipes - Dimensions
Size
(in)
(in)
(in)
(in)
2 3.06 2.38 2.00
3 4.19 3.50 3.00
4 5.19 4.50 4.00
5 6.19 5.50 5.00
6 7.19 6.50 6.00
8 9.50 8.62 8.00
10 11.62 10.75 10.00
12 13.75 12.75 12.00
Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
Cast Iron
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron.
Cast Iron Flanges - ASME/ANSI Class 125
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 125 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Cast Iron Flanges - ASME/ANSI Class 250
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 250 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Cleanouts in Draining Systems
Cleanouts provides access to the sewer for rodding.
DFU - Drainage Fixture Units
DFU are used to calculate the drainage flow from fixtures and the required capacities of sewer service systems.
Drain Waste and Vent Pipes - Hanger Spacing
Support of Drain Waste and Vent - DWV - pipes.
Draining Systems - Main Vents
Vents in draining systems protects traps against pressure differences that could cause them to siphon or blow out .
Drains and Sewers - Capacities vs. Size
Drainage Fixture Units (DFU) connected to building drains and sewers.
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures
Horizontal Storm Drain Piping
Capacities of horizontal storm drain piping systems.
Iron - Density, Specific Heats and Thermal Conductivities vs. Temperatures
Specific heat, density and thermal conductivity of iron related to temperature.
Sanitary Drainage Systems - Volume Flow
Calculate expected volume flow load in sanitary drainage systems.
Sewage Sludge - Viscosities
Viscosity of sewage sludge vs. content of solids.
Waste Water Piping - Flow Capacitiy vs. Dimension
In sewage piping and pumping systems the fluid flow rate must be kept within certain limits to avoid operating problems.
