ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
PVC pipes with belled end according ASTM D2729 Standard Specification for Poly(Vinyl Chloride) (PVC) Sewer Pipe and Fittings.
  • sewers and underground building drains for home and industry
  • storm sewers for home and industry
  • disposal fields for septic tank drains and leaching systems
  • subsoil drains for lowland and surface water drainage
  • sewer mains and sewer service
Size
(inches)
Outside Diameter
(inches)
Minimum Wall Thickness
(inches)
Approx. Weight
(lbs/ft)
3 3.250 0.069 0.478
4 4.215 0.073 0.660
6 6.275 0.093 1.266
Dimensions
ASTM D2241 - Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series) - Dimensions
Dimensions of PVC pipe SDR series.
ASTM D2665 - Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Drain, Waste, and Vent Pipe and Fittings - Dimensions
PVC drain, waste, and vent pipe dimensions.
Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipes.
Cleanouts in Draining Systems
Cleanouts provides access to the sewer for rodding.
EN 1452 - Unplasticized Poly Vinyl Chloride (PVC-U) - Dimensions
Dimensions of PVC-U pipe according EN 1452.
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures
ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161.
PVC - Polyvinyl Chloride Pipes - Supports
Distance between PVC pipe supports.
Sanitary Drainage Systems - Volume Flow
Calculate expected volume flow load in sanitary drainage systems.
Sewage Sludge - Viscosities
Viscosity of sewage sludge vs. content of solids.
Storm-Water Runoff Coefficients vs. Surface
Storm-water runoff coefficients for various surfaces
Thermal Expansion - Linear Expansion Coefficients
Linear temperature expansion coefficients for common materials like aluminum, copper, glass, iron and many more.
