ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161-1 Thermoplastics pipes for the conveyance of fluids -- Nominal outside diameters and nominal pressures -- Part 1: Metric series:
ISO 11922 - Thermoplastics Pipes for the Conveyance of Fluids - Dimensions - Metric Units
Nominal Outside Diameter
(mm)
Min. Wall Thickness (mm)
Series 20
SDR 41
PN 6.3
Series 12.5
SDR 26
PN 10
Series 8
SDR 17
PN 16
Series 6.3
SDR 13.6
PN 20
Series 5
SDR 11
PN 25
20 1.2 1.5 1.9
25 1.5 1.9 2.3
32 1.9 2.4 2.9
40 1.6 2.4 3.0 3.7
50 1.3 2.0 3.0 3.7 4.6
63 1.6 2.5 3.8 4.7 5.8
75 1.9 2.9 4.5 5.6 6.8
90 2.2 3.5 5.4 6.7 8.2
110 2.7 4.2 6.6 8.1 10.0
125 3.1 4.8 7.4 9.2 11.4
140 3.5 5.4 8.3 10.3 12.7
160 4.0 6.2 9.5 11.8 14.6
200 4.9 7.7 11.9 14.7 18.2
225 5.5 8.6 13.4 16.6 20.5
250 6.2 9.6 14.8 18.4 22..7
280 6.9 10.7 16.6 20.6 25.4
315 7.7 12.1 18.7 23.2 28.6
400 9.8 15.3 23.7 29.4 36.3
Dimensions
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
EN 1452 - Unplasticized Poly Vinyl Chloride (PVC-U) - Dimensions
Dimensions of PVC-U pipe according EN 1452.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
Pipes and Tubes - Imperial vs. Metric Sizes
SI vs. Imperial pipe sizes.
PVC - Polyvinyl Chloride Pipes - Supports
Distance between PVC pipe supports.
PVC Pipes - Equivalent Length and Pressure Loss in Fittings
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
PVC Pipes Schedule 80 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 80 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
