Polyethylene - PE - is popular material and and commonly used as water pipes in the PE 50, PEH or PE-HD (PolyEthylene High Density) qualities.
PE pipes are produced in different pressure grades - PN grades - indicating the pressure in bars the pipe supports with water at 20 oC.
Pressure grades according to European standards:
  • PN 2.5 - max pressure 2.5 bar
  • PN 4 - max pressure 4 bar
  • PN 6  - max pressure 6 bar
  • PN 10  - max pressure 10 bar
  • PN 16  - max pressure 16 bar
  • 1 bar = 105 Pa (N/m2) = 0.1 N/mm2 = 10.197 kp/m2 = 10.20 m H2O = 0.9869 atm = 14.50 psi (lbf/in2) = 106 dyn/cm2 = 750 mmHg
European PEH pipes - pressure ratings and dimensions:
Nominal Size
DN
Nominal Outside Diameter
(mm)
Pressure Rating
PN 2.5PN 4PN 6PN 10PN 16
Inside Diameter (mm)
20       16 14.4
25     21 20.4 18
32     28 26.2 23.2
40   36 35.4 32.6 29
50   46 44.2 40.8 36.2
63 59.8 58.2 55.8 51.4 45.8
75 71.2 69.2 66.4 61.4 54.4
90 85.6 83 79.8 73.6 65.4
110 104.6 101.6 97.4 90 79.8
125 118.8 115.4 110.8 102.2 90.8
140 133 129.2 124 114.6 101.6
160 152 147.6 141.8 130.8 116.2
180 171.2 166.2 159.6 147.2 130.8
200 190.2 184.6 177.2 163.6 145.4
225 214 207.8 199.2 184 163.4
250 237.6 230.7 221.6 204.6 181.6
280 266.2 258.6 248.2 229.2 203.4
315 299.6 290.8 279.2 257.8 229
355 337.6 327.8 314.8 290.6 258
400 380.4 369.4 354.6 327.4 290.6
450 428 415.6 399 368.2 327
500 475.4 461.8 443.4 409.2
560 532.6 517.2 496.6 458.4
630 599.2 581.8 558.6 515.6
710 675.2 655.6 629.6
800 760.8 738.8 709.4
900 856 831.2 798
1000 951 923.6 887
1200 1141.2 1108.2
1400 1331.4 1293
1600 1521.6 1477.6
Dimensions
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
ASTM F2389 Pressure-rated Polypropylene (PP) - Dimensions
Dimensions of pressure rated PP pipes according ASTM F2389.
Bending PE Pipes
Bending PE pipe calculator.
Cement Lined Carbon Steel Pipes
Dimensions of cement lined carbon steel pipes.
Dimensions of PVC pipes according EN 1401.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
ISO 11922 - Thermoplastics Pipes for the Conveyance of Fluids - Dimensions
ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161.
ISO 4437 - PE Pipes for Gaseous Fuels Supply - Dimensions
NPS - 'Nominal Pipe Size' and DN - 'Diametre Nominal'
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
PE - Polyethylene High Density Pipes - Weights
Weight of polyethylene pipes - metric units.
Pipes and Tubes - Imperial vs. Metric Sizes
SI vs. Imperial pipe sizes.
Piping Materials - Cost Ratios
Water Distribution Pipes - Materials
Materials used in water distribution pipes.
