Polyethylene - PE - is popular material and and commonly used as water pipes in the PE 50, PEH or PE-HD (PolyEthylene High Density) qualities.
PE pipes are produced in different pressure grades - PN grades - indicating the pressure in bars the pipe supports with water at 20 oC.
Pressure grades according to European standards:
- PN 2.5 - max pressure 2.5 bar
- PN 4 - max pressure 4 bar
- PN 6 - max pressure 6 bar
- PN 10 - max pressure 10 bar
- PN 16 - max pressure 16 bar
- 1 bar = 105 Pa (N/m2) = 0.1 N/mm2 = 10.197 kp/m2 = 10.20 m H2O = 0.9869 atm = 14.50 psi (lbf/in2) = 106 dyn/cm2 = 750 mmHg
European PEH pipes - pressure ratings and dimensions:
Nominal Size DN Nominal Outside Diameter (mm) | Pressure Rating | ||||
PN 2.5 | PN 4 | PN 6 | PN 10 | PN 16 | |
Inside Diameter (mm) | |||||
20 | 16 | 14.4 | |||
25 | 21 | 20.4 | 18 | ||
32 | 28 | 26.2 | 23.2 | ||
40 | 36 | 35.4 | 32.6 | 29 | |
50 | 46 | 44.2 | 40.8 | 36.2 | |
63 | 59.8 | 58.2 | 55.8 | 51.4 | 45.8 |
75 | 71.2 | 69.2 | 66.4 | 61.4 | 54.4 |
90 | 85.6 | 83 | 79.8 | 73.6 | 65.4 |
110 | 104.6 | 101.6 | 97.4 | 90 | 79.8 |
125 | 118.8 | 115.4 | 110.8 | 102.2 | 90.8 |
140 | 133 | 129.2 | 124 | 114.6 | 101.6 |
160 | 152 | 147.6 | 141.8 | 130.8 | 116.2 |
180 | 171.2 | 166.2 | 159.6 | 147.2 | 130.8 |
200 | 190.2 | 184.6 | 177.2 | 163.6 | 145.4 |
225 | 214 | 207.8 | 199.2 | 184 | 163.4 |
250 | 237.6 | 230.7 | 221.6 | 204.6 | 181.6 |
280 | 266.2 | 258.6 | 248.2 | 229.2 | 203.4 |
315 | 299.6 | 290.8 | 279.2 | 257.8 | 229 |
355 | 337.6 | 327.8 | 314.8 | 290.6 | 258 |
400 | 380.4 | 369.4 | 354.6 | 327.4 | 290.6 |
450 | 428 | 415.6 | 399 | 368.2 | 327 |
500 | 475.4 | 461.8 | 443.4 | 409.2 | |
560 | 532.6 | 517.2 | 496.6 | 458.4 | |
630 | 599.2 | 581.8 | 558.6 | 515.6 | |
710 | 675.2 | 655.6 | 629.6 | ||
800 | 760.8 | 738.8 | 709.4 | ||
900 | 856 | 831.2 | 798 | ||
1000 | 951 | 923.6 | 887 | ||
1200 | 1141.2 | 1108.2 | |||
1400 | 1331.4 | 1293 | |||
1600 | 1521.6 | 1477.6 | |||
Dimensions
Dimensions of thermoplastic pressure pipes. -
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe. -
Dimensions of PE pipes based on controlled outside diameter. -
ASTM F2389 Pressure-rated Polypropylene (PP) - Dimensions
Dimensions of pressure rated PP pipes according ASTM F2389. -
Bending PE Pipes
Bending PE pipe calculator. -
Cement Lined Carbon Steel Pipes
Dimensions of cement lined carbon steel pipes. -
Dimensions of PE pipes according EN 12201. -
Dimensions of PVC pipes according EN 1329. -
Dimensions of PVC pipes according EN 1401. -
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453. -
ISO 11922 - Thermoplastics Pipes for the Conveyance of Fluids - Dimensions
Dimensions of plastic pipes according ISO 11922 - metric and imperial units. -
ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161. -
ISO 4437 - PE Pipes for Gaseous Fuels Supply - Dimensions
Dimmensions of PE pipes for gaseous supply according ISO 4437. -
NPS - 'Nominal Pipe Size' and DN - 'Diametre Nominal'
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'. -
Polyethylene - PE - pipes and pressure classes. -
Water flow in SDR pressure rated PE-pipes - pressure loss and velocities - Imperial and SI units. -
Water pressure ratings for schedule 40 and schedule 80 Polyethylene plastic pipes -
Polyethylene pipe temperature and maximum operating pressure. -
PE - Polyethylene High Density Pipes - Weights
Weight of polyethylene pipes - metric units. -
Nominal pipe size, outside diameter, wall thickness, weight and working pressure. -
Chemical resistance of Polyethylene - PEH - to common products. -
Pressure loss (bar/100 m) and velocy in PE, PEH or PVC pipes with water flow. -
Pipes and Tubes - Imperial vs. Metric Sizes
SI vs. Imperial pipe sizes. -
Piping Materials - Cost Ratios
Installing cost ratios for piping materials related to carbon steel pipes. -
The Standard Dimension Ratio - SDR - is used to rate pressure pipes. -
Calculate the number of small circles that fits into an outer larger circle - ex. how many pipes or wires fits into a larger pipe or conduit. -
Water Distribution Pipes - Materials
Materials used in water distribution pipes. -
Sizing of water supply pipe lines. -
