Dimensions of PE pipes according EN 12201-2 Plastics piping systems for water supply, and for drainage and sewerage under pressure - Polyethylene (PE). Pipes:
Nominal Size
(mm)
Nominal Outside Diameter
(mm)
Mean Outside Diameter (mm)
Min.Max.
16 16 16.0 16.3
20 20 20.0 20.3
25 25 25.0 25.3
32 32 32.0 32.3
40 40 40.0 40.4
50 50 50.0 50.4
63 63 63.0 63.4
75 75 75.0 75.5
90 90 90.0 90.6
110 110 110.0 110.7
125 125 125.0 125.8
140 140 140.0 140.9
160 160 160.0 161.0
180 180 180.0 181.1
200 200 200.0 201.2
225 225 225.0 226.4
250 250 250.0 251.5
280 280 280.0 281.7
315 315 315.0 316.9
355 355 355.0 357.2
400 400 400.0 402.4
450 450 450.0 452.7
500 500 500.0 503.0
560 560 560.0 563.4
630 630 630.0 633.8
710 710 710.0 716.4
800 800 800.0 807.2
900 900 900.0 908.1
1000 1000 1000.0 1009.0
1200 1200 1200.0 1210.8
1400 1400 1400.0 1412.6
1600 1600 1600.0 1614.4
1800 1800 1800.0 1816.2
2000 2000 2000.0 2018.0
2250 2250 2250.0 2270.3
2500 2500 2500.0 2522.5
