Mechanics
  • Fasteners
  • Threads
    Thread data - metric, unified, ACME and others.
Acceleration of gravity and Newton's Second Law - SI and Imperial units.
Acceleration Units Converter
Converting between units of acceleration.
American Standard Beams - S Beam
American Wide Flange Steel Beams (W-Beams) - Dimensions and Properties in Imperial Units
Dimensions, weight, section properties, and essential data of American wide flange steel beams (W-beams) according to the ASTM A6 standard.
American Wide Flange Steel Beams: Dimensions and Properties (ASTM A6 in Metric)
Area Moment of Inertia - Typical Cross Sections II
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Area Moment of Inertia Converter
Convert between Area Moment of Inertia units.
Area Moment of Inertia with Definitions, Formulas & Calculator
Explore the area moment of inertia (second moment of area) with detailed formulas, calculation tools, and reference tables for common shapes. Essential for structural and mechanical engineering applications.
Beams Fixed at Both Ends with Continuous and Point Loads: Load & Deflection Formulas
Belts - Power Transmission and Efficiency
Calculate belts power transmission and efficiency
Belts - Pulley Diameters vs. Speed
The pulley laws - driver and driven - diameter and rpm
Bodies Moving on Inclined Planes - Acting Forces
Required forces to move bodies up inclined planes.
Bollard Forces
Friction, load and effort forces acting in ropes turned around bollards.
Cable Loads
Force and tension in cables with uniform loads.
Car Acceleration
Car acceleration calculator.
Center Mass
Calculate position of center mass.
Center of Gravity
A body and the center of gravity.
Stability - the center of gravity vs. the center of buoyancy.
Centripetal and Centrifugal Acceleration Force
Forces due to circular motion and centripetal / centrifugal acceleration.
Conn-Rod Mechanism
The connecting rod mechanism.
Conservation of Momentum
The momentum of a body is the product of its mass and velocity - recoil calculator.
Disk Brakes - Torque and Force
Forces and torque activated with disk brakes.
Drawbridge - Force and Moment vs. Elevation
Calculate the acting forces and moments when elevating drawbridges or beams.
Efficiency of Small Machine Elements
Friction and efficiency in bearings and roller chains.
Elevators - Force and Power
Required force and power to lift an elevator.
Energy
Energy is the capacity to do work.
Engineering Materials - Properties
Some typical properties of engineering materials like steel, plastics, ceramics and composites.
Equilibrant Force
The force required to keep a system of forces in equilibrium.
Fibre-reinforced Polymer Composites
Mechanical properties of fibers used to reinforce polymer composites.
Flywheels - Kinetic Energy
The kinetic energy stored in flywheels - the moment of inertia.
Force
Force Ratio
The force ratio is the load force versus the effort force.
Forces Acting on a Wedge
Large forces can be introduced with the aid of wedges.
Forces acting on Body Moving on a Horizontal Plane
The forces acting on bodies moved in horizontal planes.
Friction - Coefficients for Common Materials and Surfaces
Find friction coefficients for various material combinations, including static and kinetic friction values. Useful for engineering, physics, and mechanical design applications.
Gear Reducing Formulas
Output torque, speed and horsepower with gears.
Gear Trains - Bicycle Gearing Calculator
Gear train transmissions - bicycle gearing.
Gears
Gears effort force vs. load force.
Harmonic Oscillator
A simple harmonic oscillator.
HE-A Steel Beams
HE-B Steel Beams
HE-M Steel Beams
Properties of HE-M profile steel beams.
Hooke's Law
Hooke's law - force, elongation and spring constant.
Hot Air Balloon Lifting Force Calculator
Calculate the lifting force of a hot air balloon based on temperature difference, air density, and balloon volume. Includes formulas, explanations, and practical applications for aeronautics and physics.
Improvised Torque Wrench
Impulse and Impulse Force
Forces acting a very short time are called impulse forces.
ISO 28741 Metric Thread Dimensions for Spark Plugs
Metric threads spark plugs according ISO 28741.
Kinetic Energy
Energy possessed by an object's motion is kinetic energy.
Levers
Use levers to magnify forces.
Lifting Wheels
Loads and effort force with lifting wheels.
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Mass vs. Weight
Metric Nuts - Proof Loads
Proof loads of metric nuts - coarse and fine threads.
Modulus of Rigidity
Motors - Speed vs. Pulley Diameter
Pulley (Sheave) selection charts for motors ranging 850 - 3450 rpm.
Movement Ratio
Machines and movement ratio (velocity ratio).
Normal Flange I-Beams
Pendulum
A simple pendulum oscillates in the vertical plane due to gravity.
Poisson's Ratio – Definition, Values for Materials, and Applications
Poisson's ratio, a key material property describing the relationship between axial and lateral strain in solid materials. Typical Poisson's ratio values for metals, polymers, ceramics, and more, along with practical applications in engineering and mechanics.
Poisson's Ratios Metals
Potential Energy - Hydropower
Power
Projectile Range
Calculate the range of a projectile - a motion in two dimensions.
Pulleys
Pulleys, blocks and tackles.
Radians vs. Degrees - Definition and Conversions
Radius of Gyration in Structural Engineering
Radius of gyration describes the distribution of cross sectional area in columns around their centroidal axis.
Rolling Resistance
Rolling friction and rolling resistance.
Rotating Shafts - Torque
Torsional moments acting on rotating shafts.
Screw Jack - Effort Force vs. Load
Screw jacks and effort forces.
Section Modulus - Unit Converter
Convert between Elastic Section Modulus units.
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area.
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
Stiffness
Stiffness is resistance to deflection.
Stress
Stress in Thick-Walled Cylinders or Tubes
Radial and tangential stress in thick-walled cylinders or tubes with closed ends - with internal and external pressure.
Stress in Thin-Walled Cylinders or Tubes
Hoop and longitudinal stress thin-walled tubes or cylinders.
Support Reactions - Equilibrium
Static equilibrium is achieved when the resultant force and resultant moment equals to zero.
Three-Hinged Arches - Continuous and Point Loads
Support reactions and bending moments.
Toggle Joint
A toggle joint mechanism can be used to multiply force.
Torque - Work done and Power Transmitted
The work done and power transmitted by a constant torque.
Trusses
Common types of trusses.
Unified Thread Standards: UNC & UNF Size Charts & Specifications
Universal Gravitational Law
Gravitational attraction between two objects vs. mass of the objects and the distance between them.
Vector Addition
Online vector calculator - add vectors with different magnitude and direction - like forces, velocities and more.
Weight of Beams - Stress and Strain
Stress and deformation of vertical beams due to own weight.
Wind Load vs. Wind Speed
Wind load on surface - Wind load calculator.
Wire Rope Slings
Work done by Force
Work done by a force acting on an object.
