HE-M Steel Beams
Properties of HE-M profile steel beams.
he-a steel beam
Properties of HE-M steel beams according DIN 1025 and Euronorm 53-62
For full table with Static Parameters - Moment of Inertia and Elastic Section Modulus - rotate the screen!
HE-M Steel Beams - Properties
HEMDimensionsStatic Parameters
Moment of InertiaElastic Section Modulus
Depth
h
(mm)
Width
w
(mm)
Web Thickness
s
(mm)
Sectional Area
(cm2)
Weight
(kg/m)
Ix
(cm4)
Iy
(cm4)
Sx
(cm3)
Sy
(cm3)
100M 120 106 12 53.2 41.8 1140 399 190 75.3
120M 140 126 12.5 66.4 52.1 2020 703 288 112
140M 160 146 13 80.6 63.2 3290 1140 411 157
160M 180 166 14 97.1 76.2 5100 1760 566 212
180M 200 186 14.5 113 88.9 7480 2580 748 277
200M 220 206 15 131 103 10640 3650 967 354
220M 240 226 15.5 149 117 14600 5010 1220 444
240M 270 248 18 200 157 24290 8150 1800 657
260M 290 268 18 220 172 31310 10450 2160 780
280M 310 288 18.5 240 189 39550 13160 2550 914
300M 340 310 21 303 238 59200 19400 3480 1250
320M 359 309 21 312 245 68130 19710 3800 1280
340M 377 309 21 316 248 76370 19710 4050 1280
  • 1 cm4 = 104 mm4 = 10-8 m4 = 0.024 in4
  • 1 cm3 = 103 mm3 = 10-6 m3 = 0.061 in3
  • 1 cm2 = 102 mm2 = 10-4 m2 =  0.16 in2
  • 1 kg/m = 0.67 lb/ft
I-shaped cross-section beams:
  • Britain : Universal Beams (UB) and Universal Columns (UC)
  • Europe : IPE. HE. HL. HD and other sections
  • US : Wide Flange (WF) and H sections
