Water pressure ratings at 23 oC (73 oF) for PE plasic pipes
  • PE 2306
  • PE 3306
  • PE 3406
  • PE 2305
  • PE 1404
schedule 40 and 80 - outside diameter control - psi and bar - are indicated in the diagrams below.
PE Pipes - Schedule 40
PE Pipes - Schedule 80
Pressure Ratings of Pipes and Fittings
ABS, PE, PVC, Fiberglass and Steel Pipes - Supports
Maximum distance between supports for ABS, PE, PVC, Fiberglass and Steel Pipes.
Bending PE Pipes
Bending PE pipe calculator.
ISO 4437 - PE Pipes for Gaseous Fuels Supply - Dimensions
PE - Polyethylene High Density Pipes - Weights
Weight of polyethylene pipes - metric units.
Plastic Pipes - Friction Head Loss vs. Water Flow
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
