Dimensions of PE pipes according ASTM D3035 Standard Specification for Polyethylene (PE) Plastic Pipe (DR-PR) Based on Controlled Outside Diameter:
Nominal Pipe
Size
(in)
Outside Diameter
(in)
Min. Wall Thickness (in)
DR 32.5DR 26DR 21DR 17DR 15DR 13.5DR 11DR 9.3DR 9DR 7
1/2 0.840 0.062 0.062 0.062 0.062 0.062 0.062 00.076 0.90 0.093 0.120
3/4 1.050 0.062 0.062 0.062 0.062 0.068 0.078 0.095 0.113 0.117 0.150
1 1.315 0.062 0.062 0.063 0.077 0.084 0.097 0.120 0.141 0.146 0.188
1 1/4 1.660 0.062 0.064 0.079 0.098 0.107 0.123 0.151 0.178 0.184 0.237
1 1/2 1.900 0.062 0.073 0.090 0.112 0.123 0.141 0.173 0.204 0.211 0.271
2 2.375 0.073 0.091 0.113 0.140 0.153 0.176 0.216 0.255 0.264 0.339
3 3.500 0.108 0.135 0.167 0.206 0.226 0.259 0.318 0.376 0.389 0.500
4 4.500 0.138 0.173 0.214 0.265 0.290 0.333 0.409 0.484 0.500 0.643
6 6.625 0.204 0.255 0.315 0.390 0.427 0.491 0.602 0.712 0.736 0.946
8 8.625 0.265 0.332 0.411 0.507 0.556 0.639 0.784 0.927 0.958 1.232
10 10.750 0.331 0.413 0.512 0.632 0.694 0.796 0.977 1.156 1.194 1.536
12 12.750 0.392 0.490 0.607 .0750 0.823 0.944 1.159 1.371 1.417 1.821
14 14.000 0.431 0.538 0.667 0.824 0.903 1.037 1.273 1.505 1.556 2.000
16 16.000 0.492 0.615 0.762 0.941 1.032 1.185 1.455 1.720 1.778 2.286
18 18.000 0.554 0.692 0.857 1.059 1.161 1.333 1.636 1.935 2.000 2.571
20 20.000 0.615 0.769 0.952 1.176 1.290 1.481 1.818 2.151 2.222 2.857
22 22.000 0.677 0.846 1.048 1.294 1.419 1.630 2.000 2.366 2.444 3.143
24 24.000 0.738 0.923 1.143 1.412 1.548 1.778 2.182 2.581 2.667 3.429
Dimensions
ABS, PE, PVC, Fiberglass and Steel Pipes - Supports
Maximum distance between supports for ABS, PE, PVC, Fiberglass and Steel Pipes.
Bending PE Pipes
Bending PE pipe calculator.
Free Area Ventilation
Ventilation required for attic areas.
ISO 4437 - PE Pipes for Gaseous Fuels Supply - Dimensions
PE - Polyethylene High Density Pipes - Weights
Weight of polyethylene pipes - metric units.
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
