Polyethylene is a very popular material for pipes. It is
  • easy and light weighted
  • long living
  • low friction
  • relatively cheap
  • flexible
  • sun resistant
and resistant to chemicals.
Polyethylene and Very Good Chemical Resistance
  • Acetatic acid
  • Amonium hydroxide 30%
  • Calcium hydroxide 30%
  • Diethylene glycol
  • Ethylene glycol
  • Ethanol 100%
  • Glycerin
  • Glycol
  • Hydrogen peroxide 30%
  • Mercury
  • Methanol
  • Potassium hydroxide 30%
  • Sodium hydroxide 30%
Polyethylene and Good Chemical Resistance
  • Acetone
  • Formaldehyde 10-40%
  • Gas oil
  • Caproic acid
  • Iodine
  • Isobutanol
  • Isopropanol
  • Mineral oil
  • Motor oil
  • Natural gas
  • Gasoline
  • Phenol
  • Tranformer oil
  • Vaseline
Polyethylene and Medium Chemical Resistance
  • Dibutylether
  • Ethylene acetate 100%
  • Furfurol 100%
  • Heptane
  • Paraffin
Polyethylene and Poor Chemical Resistance
  • Diethylether
  • Ethylenechloride
  • Hydrogen peroxide 90%
  • Methylene chloride
Polyethylene and None Chemical Resistant
  • Acetylene dichloride
Corrosion
Material Properties
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Bending PE Pipes
Bending PE pipe calculator.
Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
ISO 4437 - PE Pipes for Gaseous Fuels Supply - Dimensions
PE - Polyethylene High Density Pipes - Weights
Weight of polyethylene pipes - metric units.
Polyester - Chemical Resistance
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
Polyurethane - Chemical Resistance
Chemical resistance of Polyurethane (PUR).
PP Polypropylene - Chemical Resistance
Chemical resistance of Polypropylene - PP - to acids, bases, organic substances and solvents.
PVC Polyvinyl Chloride - Chemical Resistance
Chemical resistance of Polyvinyl Chloride PVC.
Vinyl Ester - Chemical Resistance
Chemical resistance of Vinyl Ester to products as Acetone, Alcohol, Diesel oil and more.
