Polyurethane - Chemical Resistance
Polyurethane (PUR or PU) is a polymer composed of organic units joined by carbamate or urethane links.
Note that polyurethane is not a uniform class of material. The chemical resistances listed below should always be checked with manufacturing data.
Liquid | Classification |
Acetic acid 20 – 80 10% | conditionally resistant |
Acetone | not resistant |
Aluminum chloride 10% | vastly resistant |
Aluminum Salts | resistant |
Ammonia 10% | resistant |
Ammonium carbonate | not resistant |
Ammonium chloride | vastly resistant |
Aniline | not resistant |
ASTM-Fuel No. I | resistant |
ASTM-Fuel No. II | conditionally resistant |
ASTM-Fuel No. III | conditionally resistant |
ASTM-Oil I | resistant |
ASTM-Oil II | resistant |
ASTM-Oil III | resistant |
Barium Salts | resistant |
Benzene | not resistant |
Bichromate of potash | vastly resistant |
Brake fluid ATE | not resistant |
Butanol | not resistant |
Butyl acetate | not resistant |
Calcium chloride 40% | vastly resistant |
Carbon disulfide | not resistant |
Carbon tetrachloride 100% | not resistant |
Chlorobenzene | not resistant |
Chloroform | not resistant |
Chloroprene | not resistant |
Chromic acid | not resistant |
Cutting oil | conditionally resistant |
Cyclohexan | conditionally resistant |
Cyclohexanone | not resistant |
Diesel oil | vastly resistant |
Diethylether | resistant |
Diethylprestone | resistant |
Dimethylformamide | not resistant |
Ethanol | conditionally resistant |
Ethyl alcohol 100% | conditionally resistant |
Ethyl ether | conditionally resistant |
Ethylacetate | not resistant |
Ethylencloride | vastly resistant |
Formaldehyde | resistant |
Formic acid 30% | not resistant |
R-12 dichlorodifluoromethane | conditionally resistant |
R-22 chlorodifluoromethane | conditionally resistant |
Gasoline | resistant |
Glycerin | resistant |
Glycol | resistant |
Hydraulic oil SAE 90 | conditionally resistant |
Hydrochlorid acid | not resistant |
Isopropanol | not resistant |
Jet-fuel | resistant |
Kerosene | resistant |
Lactic acid 10% | not resistant |
Magnesium chloride 30% | vastly resistant |
Methanol < 5% | conditionally resistant |
Methylethylketon | conditionally resistant |
Mineral oil | conditionally resistant |
Motor oil | not resistant |
Mythyl acetate | not resistant |
Mythyl chloride | not resistant |
Mythylglycol | not resistant |
Mythylglycolacetate | not resistant |
Nitric acid 30% | not resistant |
Olive oil | resistant |
Ozone | resistant |
Paraffin oil | resistant |
Perchlore ethylene | not resistant |
Petroleum | vastly resistant |
Petroleum ether | resistant |
Phosphoric acid 50% | not resistant |
Potash lye 10% | resistant |
Potassium nitrate | vastly resistant |
Potassium permanganate | not resistant |
Sea water | resistant |
Silver salts 20% | resistant |
Soda lye 10% | resistant |
Sodium chloride 10% | vastly resistant |
Sulfuric acid 30% | short-term resistant |
Tataric acid < 10% | resistant |
Tetrahydrofuran | not resistant |
Toluene | not resistant |
Trachloroethylene | not resistant |
Trichlorethylene | not resistant |
Vegetable fats | resistant |
Vegetable oils | resistant |
Xylon | not resistant |
Chemical Resistance of Thermoplastics
Chemical resistance of thermoplastics like ABS, CPVC, PP, PVC, PE, PB, PVDF and PEX piping materials to chemicals and products ranging beer, acryl acid, diesel oil and many more.
CPVC - Chemical Resistance
Chemical resistance of CPVC - Chlorinated Poly (Vinyl Chloride) - to common chemicals and products.
Epoxy - Chemical Resistance
Chemical resistance of Epoxy to common products like Acetic acid, Alcohol, Diesel oil and more.
Polyester - Chemical Resistance
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
Polyurethane Insulation
PP Polypropylene - Chemical Resistance
Chemical resistance of Polypropylene - PP - to acids, bases, organic substances and solvents.
PVC Polyvinyl Chloride - Chemical Resistance
Chemical resistance of Polyvinyl Chloride PVC.
Rubbers and Elastomers - Chemical Resistance
Rsistance to chemicals - solvents and softeners - swelling properties.
Silicone - Chemical Resistance
Chemical resistance of silicone.
Vinyl Ester - Chemical Resistance
Chemical resistance of Vinyl Ester to products as Acetone, Alcohol, Diesel oil and more.
