Silicone - Chemical Resistance
Substance | Classification |
Acetamide, 150oC | resistant |
Acetic acid, 20oC | resistant |
Acetone, 20oC | conditionally resistant |
Ammonium hydroxide (conc.), 20oC | resistant |
Aniline, 100oC | resistant |
Petrol, 20oC | conditionally resistant |
Ball bearing fat, 150oC | resistant |
Brake fluid AT, 100oC | resistant |
Butanol, 117oC | conditionally resistant |
Butylacetate, 20oC | conditionally resistant |
Calcium hydroxide, (saturated), 20oC | resistant |
Carbon tetrachloride, 20oC | conditionally resistant |
Chlorbenzene, 20oC | conditionally resistant |
Carbolineum, 20oC | resistant |
Clophene, 150oC | resistant |
Cloroform, 20oC | not resistant |
Compressor oil, light, 150oC | resistant |
Diphenyl, 150oC | conditionally resistant |
Diesel oil, 20oC | conditionally resistant |
Dinamo oil, 150oC | conditionally resistant |
Hydrofluor acid 5%, 20oC | not resistant |
Gear oil DTE BB, 150oC | resistant |
Gear oil DTE HH, 150oC | resistant |
Gear oil DTE extra heavy, 150oC | resistant |
Gear oil Type SEA 90, 150oC | resistant |
Glycerin, 100oC | resistant |
Hexa ethoxydisiloxane, 20oC | conditionally resistant |
High pressure compressor oil, 150oC | resistant |
Isopropyl alcohol 82 | conditionally resistant |
Mineral oil, 20oC | conditionally resistant |
Potassium, 20oC%, 20oC | resistant |
Potassium hydroxide 50%, 20oC | resistant |
Potassium permanganate solution, 20oC | resistant |
Prestone, 20oC | resistant |
Salt, cooking solution 10%, 20oC | resistant |
Linseed oil, 100oC | resistant |
Methanol 65 | conditionally resistant |
Methylen chloride, 20oC | not resistant |
Mineral oil ASTM No. 1, 150oC | resistant |
Mineral oil ASTM No. 3, 150oC | conditionally resistant |
Mineral oil SEA 10, 150oC | resistant |
Mineral oil SEA, 20oC, 150oC | resistant |
Mineral oil SEA 30, 150oC | resistant |
Mono styrene, 20oC | conditionally resistant |
Motor oil viscose static, 150oC | resistant |
Sodium, 20oC%, 20oC | resistant |
Soda 50%, 20oC | resistant |
Nitrobenzene, 20oC | resistant |
Oleic acid, 150oC | not resistant |
Olive oil, 150oC | resistant |
Perchlor, 20oC | not resistant |
Petroleum ether, 20oC | not resistant |
Petroleum, 20oC | conditionally resistant |
Phenol 60 | resistant |
Phosphoric acid 30%, 20oC | resistant |
Pyridine, 20oC | conditionally resistant |
Regulator oil, 150oC | not resistant |
Castor oil, 150oC | resistant |
Hydrochlorid acid 10%, 20oC | resistant |
Nitric acid conc., 20oC | not resistant |
Nitric acid 10%, 20oC | conditionally resistant |
Sulfuric acid, conc., 20oC | not resistant |
Sulfuric acid, 10%, 20oC | resistant |
Shock absorber oil, 20oC | resistant |
Turbentine oil, 20oC | conditionally resistant |
Toluene, 20oC | conditionally resistant |
Transformer oil, 150oC | conditionally resistant |
Tri, 20oC | not resistant |
Tri glycol, 20oC | resistant |
Vaseline, 150oC | resistant |
Water, 100oC | resistant |
Hydrogen peroxide 30%, 20oC | resistant |
Hydrogen superoxide 30%, 20oC | resistant |
In general - be careful with silicone tubes and gaskets with oil products. Depending on the content of the products silicone may - or may not - be resistant.
Polyester - Chemical Resistance
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
Polyurethane - Chemical Resistance
Chemical resistance of Polyurethane (PUR).
PP Polypropylene - Chemical Resistance
Chemical resistance of Polypropylene - PP - to acids, bases, organic substances and solvents.
PVC Polyvinyl Chloride - Chemical Resistance
Chemical resistance of Polyvinyl Chloride PVC.
Vinyl Ester - Chemical Resistance
Chemical resistance of Vinyl Ester to products as Acetone, Alcohol, Diesel oil and more.
