Dimensions of thermoplastic gas pipes according ASTM D2513 Standard Specification for Thermoplastic Gas Pressure Pipe, Tubing, and Fittings:
CTS (Copper Tube Sized)
ASTM D2513 - Thermoplastic Gas Pipes - Dimensions - CTS (Copper Tube Sized)
Nominal Tubing Size
(CTS)
(in)
Outside Diameter
(in)
Min. Wall Thickness
(in)
1/4 0.375 0.062
3/8 0.500 0.062
1/2 0.625 0.062
1/2 0.625 0.090
1/2 0.625 0.104
3/4 0.875 0.062
3/4 0.875 0.077
3/4 0.875 0.090
1 1.125 0.062
1 1.125 0.090
1 1.125 0.099
1 1.125 0.101
1 1.125 0.121
1 1/4 1.375 0.062
1 1/4 1.375 0.090
1 1/4 1.375 0.121
1 3/4 1.875 0.062
  • 1 inch = 25.4 mm
IPS (Iron Pipe Sized)
ASTM D2513 - Thermoplastic Gas Pipes - Dimensions - IPS (Iron Pipe Sized)
Nominal Pipe Size
(IPS)
(in)
SDRMin. Wall Thickness
(in)
1/2 0.062
1/2 11.0 0.076
1/2 9.33 0.090
3/4 0.090
3/4 11.0 0.095
3/4 Sch 40 0.113
1 0.90
1 13.5 0.097
1 11.0 0.120
1 9.9 0.133
1 9.33 0.140
1 1/4 0.090
1 1/4 17.0 0.098
1 1/4 13.5
0.123
1 1/4 Sch 40 0.140
1 1/4 11.0 0.151
1 1/4 10.0 0.166
1 1/4 9.33 0.178
1 1/4 6.0 0.277
1 1/2 0.090
1 1/2 17 0.112
1 1/2 13.5 0.141
1 1/2 Sch 40 0.145
1 1/2 11 0.173
2 21 0.113
2 17 0.140
2 Sch 40 0.154
2 13.5 0.176
2 11 0.216
2 9.33 0.255
2 1/2 21 0.137
2 1/2 17 0.169
2 1/2 13.5 0.213
2 1/2 11 0.261
3 21 0.167
3 17 0.206
3 Sch 40 0.216
3 13.5 0.259
3 11.5 0.304
3 11 0.318
3 9.33 0.375
3 1/2 21 0.190
3 1/2 17 0.236
3 1/2 13.5 0.296
3 1/2 11 0.363
4 21 0.214
4 19 0.237
4 17 0.265
4 13.5 0.333
4 11.5 0.391
4 11.0 0.409
4 9.33 0.482
5 21.6 0.258
5 21 0.265
5 17 0.327
5 13.5 0.412
5 11 0.506
6 32.5 0.204
6 26 0.255
6 23.7 0.280
6 21 0.315
6 17 0.390
6 13.5 0.491
6 11.5 0.576
6 11.0 0.602
8 32.5 0.265
8 26 0.332
8 21 0.411
8 17 0.507
8 13.5 0.639
8 11.5 0.750
8 11 0.784
10 32.5 0.331
10 26 0.413
10 21 0.512
10 17 0.632
10 13.5 0.796
10 11.5 0.935
10 11 0.977
12 32.5 0.392
12 26 0.490
12 21 0.607
12 17 0.750
12 13.5 0.944
12 11.5 1.109
12 11 1.159
Dimensions
ABS, PE, PVC, Fiberglass and Steel Pipes - Supports
Maximum distance between supports for ABS, PE, PVC, Fiberglass and Steel Pipes.
PE - Polyethylene High Density Pipes - Weights
Weight of polyethylene pipes - metric units.
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
