NPS (Nominal Pipe Size) Guide: Dimensions, Charts & Specifications
Pipes are made of a wide variety of materials - like galvanized steel, black steel, copper, cast iron, concrete, and various plastics such as ABS, PVC, CPVC, polyethylene, polybutylene and more.
Pipes are identified by "nominal" or "trade" names that are loosely related to the actual dimensions. For instance, a 2-inch galvanized steel pipe has an inside diameter of about 2 1/8 inches and an outside diameter of about 2 5/8 inches.
In plumbing pipe size is referred to as nominal pipe size - NPS, or "Nominal Pipe Size". The metric equivalent is called DN or "diametre nominel". The metric designations conform to International Standards Organization (ISO) usage and apply to all plumbing, natural gas, heating oil, and miscellaneous piping used in buildings. The use of NPS does not conform to American Standard pipe designations where the term NPS means "National Pipe Thread Straight".
ISO 6708 - Pipework components - Definition and selection of DN (nominal size)
ISO 6708 defines the nominal size - DN - as an alphanumeric designation of size for reference purposes. It comprises the letters DN followed by a dimensionless whole number which is indirectly related to the physical size in millimetres of the bore (ID) or outside diameter (OD) of the end connections.
Outside diameters for metric and imperial standards are indicated in the table below.
| Nominal Pipe Size - NPS | Outside Diameter (mm) | ||||
| DN (mm) | Inch | ISO 6708 Pipework components | DIN EN 10220 Seamless Steel Pipes | DIN EN 10255 Threaded Tube | ASME |
| 10 | 3/8 | 17.2 | |||
| 15 | 1/2 | 21.3 | 20.0 | 21.3 | 21.3 |
| 20 | 3/4 | 26.9 | 25.0 | 26.9 | 26.7 |
| 25 | 1 | 33.7 | 30.0 | 33.7 | 33.4 |
| 32 | 1 1/4 | 42.4 | 38.0 | 42.4 | 42.2 |
| 40 | 1 1/2 | 48.3 | 44.5 | 48.3 | 48.3 |
| 50 | 2 | 60.3 | 57.0 | 60.3 | 60.3 |
| - | 2 1/2 | - | - | 73.0 | 73.0 |
| 65 | - | 76.1 | 76.1 | 76.1 | - |
| 80 | 3 | 88.9 | 88.9 | 88.9 | 88.9 |
| - | 3 1/2 | - | - | 101.6 | 101.6 |
| 100 | 4 | 114.3 | 108 | 114.3 | 114.3 |
| 125 | - | 139.7 | 133 | 139.7 | - |
| - | 5 | - | - | 141.3 | 141.3 |
| 150 | 6 | 168.3 | 159 | 168.3 | 168.3 |
| 200 | 8 | 219.1 | 216 | 219.1 | 219.1 |
| 250 | 10 | 273.0 | 267 | 273.0 | 273.0 |
| 300 | 12 | 323.9 | 318 | 323.9 | 323.8 |
| 350 | 14 | 355.6 | 368 | 355.6 | 355.6 |
| 400 | 16 | 406.4 | 419 | 406.4 | 406.4 |
| 450 | 18 | 457 | 470 | 457 | 457 |
| 500 | 20 | 508 | 521 | 508 | 508 |
| 600 | 24 | 610 | 622 | 610 | 610 |
| 700 | 28 | 711 | 720 | 711 | 711 |
| 800 | 32 | 813 | 820 | 813 | 813 |
| 900 | 36 | 914 | 920 | 914 | 914 |
| 1000 | 40 | 1016 | 1020 | 1016 | 1016 |
| 1200 | 48 | 1220 | 1219 | 1219 | |
- NPS - Nominal Pipe Size - references inside diameter of pipe
- IPS - Iron Pipe Size - initially a system established to designate the pipe size representing the approximate inside diameter of the pipe
- DIPS - Ductile Iron Pipe Size - references inside diameter of pipe
- CTS - Copper Tube Size - references outside diameter of tube
• Piping Systems
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipe - Dimensions
ASTM B88 - Seamless Copper Water Tubes - Dimensions
AWWA C115 - Ductile-Iron Threaded Pipe - Dimensions
Dimensions of threaded ductile-iron pipe according AWWA C115.
AWWA C151 - Ductile-Iron Pipe Centrifugally Cast - Dimensions
Dimensions of ductile-iron pipes according AWWA C151/A.21.51.
Hot Water Heating System Online Design Application
Pipe vs. Tube
Pipes and tubes are not exactly the same
Pipe Weight Calculator
Pipes - Fractional Equivalents
Fractional vs. decimal inches.
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Pipes and Tubes - Imperial vs. Metric Sizes
SI vs. Imperial pipe sizes.
Pipes with Water Content - Weight and Volume
Estimate water content in pipes - weight and volume.
PN Pressure Ratings for Flanges: Specifications & Standards
Schedule - Terminology
Introduction to the schedule terminology of pipes.
