Pipes - Fractional Equivalents
Fraction (in) | Decimal Equivalent (in) |
1/64 | 0.015625 |
1/32 | 0.031250 |
3/64 | 0.046875 |
1/16 | 0.062500 |
5/64 | 0.078125 |
3/32 | 0.093750 |
7/64 | 0.109375 |
1/8 | 0.125000 |
9/64 | 0.140625 |
5/32 | 0.156250 |
11/64 | 0.171875 |
3/16 | 0.187500 |
13/64 | 0.203125 |
7/32 | 0.218750 |
15/64 | 0.234375 |
1/4 | 0.250000 |
17/64 | 0.265625 |
9/32 | 0.281250 |
19/64 | 0.296875 |
5/16 | 0.312500 |
21/64 | 0.328125 |
11/32 | 0.343750 |
23/64 | 0.359375 |
3/8 | 0.375000 |
25/64 | 0.390625 |
13/32 | 0.406250 |
27/64 | 0.421875 |
7/16 | 0.437500 |
29/64 | 0.453125 |
15/32 | 0.468750 |
31/64 | 0.484375 |
1/2 | 0.500000 |
33/64 | 0.515625 |
17/32 | 0.531250 |
35/64 | 0.546875 |
9/16 | 0.562500 |
37/64 | 0.578125 |
19/32 | 0.593750 |
39/64 | 0.609375 |
5/8 | 0.625000 |
41/64 | 0.640625 |
21/32 | 0.656250 |
43/64 | 0.671875 |
11/16 | 0.687500 |
45/64 | 0.703125 |
23/32 | 0.718750 |
47/64 | 0.734375 |
3/4 | 0.750000 |
49/64 | 0.765625 |
25/32 | 0.781250 |
51/64 | 0.796875 |
13/16 | 0.812500 |
53/64 | 0.828125 |
27/32 | 0.843750 |
55/64 | 0.859375 |
7/8 | 0.875000 |
57/64 | 0.890625 |
29/32 | 0.906250 |
59/64 | 0.921875 |
15/16 | 0.937500 |
61/64 | 0.953125 |
31/32 | 0.968750 |
63/64 | 0.984375 |
• Mathematics
• Piping Systems
Fraction to Decimal Inches Conversion: Chart & Calculator
The inches fractional and decimal equivalents.
Inches to Millimeters Conversion Calculator
Convert fractional and/or decimal inches to metric mm - and vice versa.
Length - Online Unit Converter
Convert between length units like meters, feet, inches, nautical miles and more.
NPS (Nominal Pipe Size) Guide: Dimensions, Charts & Specifications
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
Piping Equations
Calculate cross-sectional areas, weight of empty pipes, weight of pipes filled with water, inside and outside surface areas.
Threads commonly used in Piping
Piping thread standards.
