Pipe Equations
Cross Sectional inside Pipe Area
Cross-sectional inside area of a pipe can be calculated as
Ai = π (di / 2)2
= π di 2 / 4 (1)
Ai = cross-sectional inside area of pipe (m2, in2)
di = inside diameter (m, in)
Cross Sectional Pipe Wall Area
The cross-sectional wall area - or area of piping material - can be calculated as
Am = π (do / 2)2 - π (di / 2)2
= π (do 2 - di 2) / 4 (2)
Am = cross-sectional wall area of pipe (m2, in2)
do = outside diameter (m, in)
Weight of Empty Pipes
Weight of empty pipes per unit length can be calculated as
wp = ρm Am
= ρm (π (do / 2)2 - π (di / 2)2)
= ρm π (do2 - di2) / 4 (3)
wp = weight of empty pipe per unit length (kg/m, lb/in)
ρs = density of pipe material (kg/m3, lb/in3)
Weight of Liquid in Pipes
Weight of liquid in pipes per unit length can be calculated as
wl = ρl A
= ρl π (di / 2)2
= ρl π di2 / 4 (4)
wl = weight of liquid in pipe per unit length of pipe (kg, lb)
ρl = density of liquid (kg/m3, lb/in3)
Weight of Pipe filled with Liquid
Weight of pipe filled with liquid per unit length can be calculated as
w = wl + wp (5)
w = weight of pipe and liquid per unit length of pipe (kg, lb)
Outside Surface Area of Pipes
Outside surface area of steel pipes per unit length can be calculated as
Ao = 2 π (do / 2)
= π do (6)
Ao = outside area of pipe - per unit length of pipe (m2, in2)
Inside Surface Area of Pipes
Inside surface area of steel pipes per unit length can be calculated as
Ai = 2 π (di / 2)
= π di (7)
Ai = inside area of pipe - per unit length of pipe (m2, in2)
• Dimensions
ANSI Schedule 40 Steel Pipes - Dimensions
Area Units Converter
Convert between units of area.
Darcy-Weisbach Equation - Major Pressure and Head Loss due to Friction
Hazen-Williams Friction Loss Equation - calculating Head Loss in Water Pipes
Ice Loaded Pipelines
Ice coat weigth on horizontal pipe lines.
Manning's Formula and Gravity Flow
Calculate cross-sectional average velocity flow in open channels.
Pipe Formulas
Pipe and Tube Equations - moment of inertia, section modulus, traverse metal area, external pipe surface and traverse internal area - imperial units
Pipe Weight Calculator
Pipes - Fractional Equivalents
Fractional vs. decimal inches.
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Pipes and Tubes - Water Content
Water content in steel pipes and copper tubes.
Welded Steel Pipes - Weights
Nominal weights of welded steel pipes ranging 26 - 60 inches.
