Manning's Formula and Gravity Flow
Manning's equation is an empirical equation that can be used to calculate cross-sectional average velocity flow in open channels
v = (kn / n) Rh 2/3 S1/2                            (1)
v = cross-sectional mean velocity (ft/s, m/s)
kn = 1.486 for English units and kn = 1.0 for SI units
n = Manning coefficient of roughness - ranging from 0.01 (a clean and smooth channel) to 0.06 (a channel with stones and debris, 1/3 of vegetation)
Rh = hydraulic radius (ft, m)
S = slope - or gradient - of pipe (ft/ft, m/m)
The Manning coefficients n in the English (Imperial) are equal to the coefficients in the SI system. The Manning coefficient is not dimensionless but the units are often omitted.
Units for (kn / n) in the SI system vs. the Imperial system can be expressed as:
(kn / n) = m1/3 / s
    = 1.4859 ft1/3 / s
Hydraulic radius can be expressed as
Rh = A / Pw                                (2)
A = cross sectional area of flow (ft2, m)
Pw = wetted perimeter (ft, m)
Download and print Gravity Flow - Mannings Equation Chart
The volume flow in the channel can be calculated as
q = A v
   = A (kn / n) Rh 2/3 S1/2                           (3)
q = volume flow (ft3/s, m3/s)
A = cross-sectional area of flow (ft2, m2)
Example - Flow in an Open Channel
A channel with the shape of an half circle is 100% filled. The diameter of the half circle is 500 mm (0.5 m) and the channel is made of concrete with Manning coefficient 0.012 . The slope of the channel is 1/100 m/m .
make 3D models with the free Engineering ToolBox Sketchup Extension !
The cross section area of the half circle flow can be calculated as
A = (0.5 π ((0.5 m) / 2)2)
= 0.098 m2
The wetted perimeter of the half circle flow can be calculated as
P = 0.5 2 π (0.5 m) / 2)
= 0.785 m
The hydraulic radius of the channel can be calculated from (2) as
Rh = A / P
= ( 0.098 m2>) / ( 0.785 m)
= 0.125 m
The cross sectional mean velocity can be calculated from (1) as
= (1.0 / 0.012) (0.125 m)2/3 (1/100 m/m)1/2
= 2.1 m/s
The volume flow can be calculated from (3) as
q = A v
=  ( 0.098 m2) (2.1 m/s)
= 0.20 m3/s
Gravity Flow Calculator - Half Filled Circular Pipe
The Gravity Flow Calculator is based on the equations and the example above above. It's valid for half filled circular pipe.
Flow Measurements
Fluid Mechanics
California Pipe Flow Metering Method
Calculate the discharge length from the open end of a partially filled horizontal pipe.
Chezys Conduit Flow Equation
Calculating volume flow and velcity in open conduits.
Flow Section Channels - Geometric Relationships
Geometric relationships like area, wetted perimeter and hydraulic diameter.
Froude Number
Introduction to the Froude Number.
Hazen-Williams Water Flow Formula: Head Loss, Data, Charts & Calculator
Manning’s Roughness Coefficients for Open Channel Flow
Manning's roughness coefficients for some common materials.
Piping Equations
Calculate cross-sectional areas, weight of empty pipes, weight of pipes filled with water, inside and outside surface areas.
Rainfall on Roofs and Gutter Slopes
Draining of roof areas and recommended gutter slopes
Sewage Sludge - Viscosities
Viscosity of sewage sludge vs. content of solids.
Storm-Water Conductors
Roof drain capacities.
Storm-Water Runoff Coefficients vs. Surface
Storm-water runoff coefficients for various surfaces
Surface Roughness vs. Mechanical Processing
Mechanical production methods and their surface roughness.
