Manning’s Roughness Coefficients for Open Channel Flow
The Manning's roughness coefficient is used in the Manning's equation to calculate flow in open channels.
Coefficients for some commonly used surface materials:
Surface Material | Manning's Roughness Coefficient - n - |
Asbestos cement | 0.011 |
Asphalt | 0.016 |
Brass | 0.011 |
Brick and cement mortar sewers | 0.015 |
Canvas | 0.012 |
Cast or Ductile iron, new | 0.012 |
Clay tile | 0.014 |
Concrete - steel forms | 0.011 |
Concrete (Cement) - finished | 0.012 |
Concrete - wooden forms | 0.015 |
Concrete - centrifugally spun | 0.013 |
Copper | 0.011 |
Corrugated metal | 0.022 |
Earth, smooth | 0.018 |
Earth channel - clean | 0.022 |
Earth channel - gravelly | 0.025 |
Earth channel - weedy | 0.030 |
Earth channel - stony, cobbles | 0.035 |
Floodplains - pasture, farmland | 0.035 |
Floodplains - light brush | 0.050 |
Floodplains - heavy brush | 0.075 |
Floodplains - trees | 0.15 |
Galvanized iron | 0.016 |
Glass | 0.010 |
Gravel, firm | 0.023 |
Lead | 0.011 |
Masonry | 0.025 |
Metal - corrugated | 0.022 |
Natural streams - clean and straight | 0.030 |
Natural streams - major rivers | 0.035 |
Natural streams - sluggish with deep pools | 0.040 |
Natural channels, very poor condition | 0.060 |
Plastic | 0.009 |
Polyethylene PE - Corrugated with smooth inner walls | 0.009 - 0.015 |
Polyethylene PE - Corrugated with corrugated inner walls | 0.018 - 0.025 |
Polyvinyl Chloride PVC - with smooth inner walls | 0.009 - 0.011 |
Rubble Masonry | 0.017 - 0.022 |
Steel - Coal-tar enamel | 0.010 |
Steel - smooth | 0.012 |
Steel - New unlined | 0.011 |
Steel - Riveted | 0.019 |
Vitrified clay sewer pipe | 0.013 - 0.015 |
Wood - planed | 0.012 |
Wood - unplaned | 0.013 |
Wood stave pipe, small diameter | 0.011 - 0.012 |
Wood stave pipe, large diameter | 0.012 - 0.013 |
AWWA C115 - Ductile-Iron Threaded Pipe - Dimensions
Dimensions of threaded ductile-iron pipe according AWWA C115.
AWWA C151 - Ductile-Iron Pipe Centrifugally Cast - Dimensions
Dimensions of ductile-iron pipes according AWWA C151/A.21.51.
Fluid Mechanics - Imperial and SI Units vs. Dimensions
Imperial (USCS) and SI dimensions and units terminology in fluid mechanics.
Grit Size vs. Surface Roughness
Comparing sandpaper grit size and surface roughness.
Manning's Formula and Gravity Flow
Calculate cross-sectional average velocity flow in open channels.
Sandpapers - Grit Sizes
Grit sizes ranging 12 - 600.
Surface Roughness Coefficients
Surface coefficients that can be used to calculate friction and major pressure loss for fluid flow with surfaces like concrete, galvanized steel, corroded steel and more.
Surface Roughness vs. Abrasive Grain Size
U.S. mesh size vs. surface roughness.
Surface Roughness vs. Mechanical Processing
Mechanical production methods and their surface roughness.
