AWWA C151 - Ductile-Iron Pipe Centrifugally Cast - Dimensions
Typical dimensions of ductile-iron pipes according AWWA C151/A.21.51 Ductile-Iron Pipe, Centrifugally Cast.
Nominal Size (inches) | Outside Diameter (inches) | Pressure Class | ||||
150 | 200 | 250 | 300 | 350 | ||
Wall Thickness (inches) | ||||||
3 | 3.96 | 0.25 | 0.25 | 0.25 | 0.25 | 0.25 |
4 | 4.80 | 0.26 | 0.26 | 0.26 | 0.26 | 0.26 |
6 | 6.90 | 0.25 | 0.25 | 0.25 | 0.25 | 0.25 |
8 | 9.05 | 0.27 | 0.27 | 0.27 | 0.27 | 0.27 |
10 | 11.10 | 0.29 | 0.29 | 0.29 | 0.29 | 0.29 |
12 | 13.20 | 0.31 | 0.31 | 0.31 | 0.31 | 0.31 |
14 | 15.30 | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 |
16 | 17.40 | 0.34 | 0.34 | 0.34 | 0.34 | 0.34 |
18 | 19.50 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 |
20 | 21.60 | 0.36 | 0.36 | 0.36 | 0.36 | 0.39 |
24 | 25.80 | 0.38 | 0.38 | 0.38 | 0.41 | 0.44 |
30 | 32.00 | 0.39 | 0.39 | 0.43 | 0.47 | 0.51 |
36 | 38.30 | 0.43 | 0.43 | 0.48 | 0.53 | 0.58 |
42 | 44.50 | 0.47 | 0.47 | 0.53 | 0.59 | 0.65 |
48 | 50.80 | 0.51 | 0.51 | 0.58 | 0.65 | 0.72 |
54 | 57.56 | 0.57 | 0.57 | 0.65 | 0.73 | 0.81 |
AWWA C115 - Ductile-Iron Threaded Pipe - Dimensions
Dimensions of threaded ductile-iron pipe according AWWA C115.
Cast Iron
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron.
Gas Pipes - Approved Materials
Materials approved for gas pipes.
Hazen-Williams Friction Loss Coefficients: Data & Reference Guide
Hazen-Williams friction loss coefficients for commonly used piping materials.
Manning’s Roughness Coefficients for Open Channel Flow
Manning's roughness coefficients for some common materials.
NPS (Nominal Pipe Size) Guide: Dimensions, Charts & Specifications
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
Piping Materials - Galvanic Corrosion
Connecting pipes of different materials may cause galvanic corrosion and serious damage.
Steel Pipes - Maximum Water Flow Capacities vs. Size
Maximum water flow capacities in steel pipes - pipe dimensions ranging 2 - 24 inches.
Steel Pipes Schedule 40 - Pressure Loss
Water flow and pressure loss in schedule 40 steel pipes - Imperial and SI units - gallons per minute, liters per second and cubic meters per hour.
