Hazen-Williams Friction Loss Coefficients: Data & Reference Guide
Hazen-Williams coefficients are used in the Hazen-Williams equation calculate friction loss in ducts and pipes. Coefficients for some common materials used in ducts and pipes are indicated below:
| Material | Hazen-Williams Coefficient - c - |
| ABS - Acrylonite Butadiene Styrene | 130 |
| Aluminum | 130 - 150 |
| Asbestos Cement | 140 |
| Asphalt Lining | 130 - 140 |
| Brass | 130 - 140 |
| Brick sewer | 90 - 100 |
| Cast-Iron - new unlined (CIP) | 130 |
| Cast-Iron 10 years old | 107 - 113 |
| Cast-Iron 20 years old | 89 - 100 |
| Cast-Iron 30 years old | 75 - 90 |
| Cast-Iron 40 years old | 64-83 |
| Cast-Iron, asphalt coated | 100 |
| Cast-Iron, cement lined | 140 |
| Cast-Iron, bituminous lined | 140 |
| Cast-Iron, sea-coated | 120 |
| Cast-Iron, wrought plain | 100 |
| Cement lining | 130 - 140 |
| Concrete | 100 - 140 |
| Concrete lined, steel forms | 140 |
| Concrete lined, wooden forms | 120 |
| Concrete, old | 100 - 110 |
| Copper | 130 - 140 |
| Corrugated Metal | 60 |
| Ductile Iron Pipe (DIP) | 140 |
| Ductile Iron, cement lined | 120 |
| Fiber | 140 |
| Fiber Glass Pipe - FRP | 150 |
| Galvanized iron | 120 |
| Glass | 130 |
| Lead | 130 - 140 |
| Metal Pipes - Very to extremely smooth | 130 - 140 |
| Plastic | 130 - 150 |
| Polyethylene, PE, PEH | 140 |
| Polyvinyl chloride, PVC, CPVC | 150 |
| Smooth Pipes | 140 |
| Steel new unlined | 140 - 150 |
| Steel, corrugated | 60 |
| Steel, welded and seamless | 100 |
| Steel, interior riveted, no projecting rivets | 110 |
| Steel, projecting girth and horizontal rivets | 100 |
| Steel, vitrified, spiral-riveted | 90 - 110 |
| Tin | 130 |
| Vitrified Clay | 110 |
| Wrought iron, plain | 100 |
| Wooden or Masonry Pipe - Smooth | 120 |
| Wood Stave | 110 - 120 |
AWWA C115 - Ductile-Iron Threaded Pipe - Dimensions
Dimensions of threaded ductile-iron pipe according AWWA C115.
AWWA C151 - Ductile-Iron Pipe Centrifugally Cast - Dimensions
Dimensions of ductile-iron pipes according AWWA C151/A.21.51.
Fluid Mechanics - Imperial and SI Units vs. Dimensions
Imperial (USCS) and SI dimensions and units terminology in fluid mechanics.
Hazen-Williams Pressure Loss Equation
The Hazen-Williams equation can be used to calculate the pressure drop (psi) or friction loss in pipes or tubes.
Hazen-Williams Water Flow Formula: Head Loss, Data, Charts & Calculator
Plastic Pipes - Friction Head Loss vs. Water Flow
