Grit Size vs. Surface Roughness
Approximate comparision of sandpaper grit size and surface roughness:
Grit Size | Surface Roughness (10-6 m) |
80 | 1.80 |
120 | 1.32 |
150 | 1.06 |
180 | 0.76 |
240 | 0.38 |
320 | 0.30 |
500 | 0.18 |
600 | 0.13 |
Manning’s Roughness Coefficients for Open Channel Flow
Manning's roughness coefficients for some common materials.
Sandpapers - Grit Sizes
Grit sizes ranging 12 - 600.
Softwood Lumber - Grading
Rough lumber, surfaced lumber (dressed), worked lumber, shop and factory lumber and yard lumber.
Surface Roughness Coefficients
Surface coefficients that can be used to calculate friction and major pressure loss for fluid flow with surfaces like concrete, galvanized steel, corroded steel and more.
Surface Roughness vs. Abrasive Grain Size
U.S. mesh size vs. surface roughness.
Surface Roughness vs. Mechanical Processing
Mechanical production methods and their surface roughness.
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
