Softwood Lumber - Grading
Rough Lumber
Sawn, trimmed and edged lumber. The faces are rough with saw marks.
Surfaced Lumber
Rough lumber smoothed by surfacing machines. Subcategories based on the number of sides and edges that have been smoothed.
- S1S - Surfaced on 1 Sides
- S2S - Surfaced on 2 Sides
- S3S - Surfaced on 3 Sides
- S4S - Surfaced on 4 Sides
- S1E - Surfaced 1 Edge
- S2E - Surfaced 2 Edges
- S1S1E - Surfaced 1 Side and 1 Edge
- S1S2E - Surfaced 1 Side and 2 Edges
Note that S4S lumber planed and surfaced all four sides will be noticeably less than in its nominal dimension.
Worked Lumber
Surfaced lumber that has been matched and patterned.
Shop and Factory Lumber
Millwork lumber - used for molding, door jambs and windows frames.
Structural Lumber or Yard Lumber
Yard lumber used for house framing, sheathing, concrete forms.
Yard lumber or structural softwood lumber is subdivided in
- Boards - no more than 1 inch thick and 4-12 inches wide
- Planks - more than 1 inch thick and more than 6 inches wide
- Timbers - width and thickness greater than 5 inches
Board Feet Chart and Calculator
Board feet is used as a volume measurement of lumber.
Density of Wood Species: Data & Material Guide
Glue-Laminated Timber - Dimensions
Common sizing of glue-laminated timber.
Grit Size vs. Surface Roughness
Comparing sandpaper grit size and surface roughness.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Hardwood Lumber - Dimensions
Sizing of hardwood lumber.
Horizontal Roof Rafters - Maximum Spans
Douglas Fir in horizontal roof rafters and maximum spans.
Lumber - Surface Finishing
Lumber and surface finishing abbreviations.
Lumber Weights: Green, Kiln-Dried & Pressure-Treated Wood
Maximum Floor Joist Span
No. 1 and No. 2 Grade of Douglas fir and maximum span floor joists - imperial units
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Softwood Lumber - Dimensions
Commercial softwood lumber dimension chart - nominal and actual sizes.
Softwood Lumber - Standard Sizes
Nominal and minimum-dressed lumber sizes.
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Structural Lumber - Properties
Wood Beams - Strength of Material
